Question about Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool washer overflow during wash cycle
Washer overflows while washing cloth.I push the off button an water starts to lower in tub. push start again then water level rises to point of overflow. Have replaced pressure switch today. I ran first load worked great. Ran second load , overflowed. any advise would be greatly appreciated. thanks
  • jbl9134 Oct 17, 2008
    Thanks for the response, but I have checked the pressure hose for obstructions. Water seem to enter the tub while in the wash mode from under the tub.thanks
    Novelist:
    Champion:
  • 261 Answers
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
  • John Robbins
    John Robbins Oct 17, 2008
    Well this is good, to be clear water enters while washing? This would point to a timer issue.
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Small puddle of water underneath washer when wash cycle was completed.
That could be 1 of a couple things.
1) During the agitate cycle... some water could've made it out of tub.
2) Possible Tub Crack (or overflow line)
3) Check your inlet lines
I would run it again watching it very carefully to determine if any of these are the problem.
Dec 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
I manually put water in my washer; water stuck inside
drain hose kinked or belt off pump . lower drain hose to floor if empties the pump is the problem
Apr 17, 2009 | Whirlpool Washing Machines
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaks occur in spin/empty cycle
I had the same problem, you need to turn the washing machine on it's side and look for a pin hole leak in the seam of the plastic holding drum on the bottom. I used a silicone sealant, "GOOP" , let it dry for 1 day and problem solved. It has not leaked in two years. good luck!
Nov 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
413 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
