Question about Dewalt 18 Volt Compact Drill Kit
Dewalt DW988 drill chuck
My wife install a very small drill bit in my DW988 and now the chuch is stuck closed. Any solutions short of buying a new one.
  • Anonymous Mar 31, 2014
    broken drill bit stuck in chuck, can't open
    Novelist:
  • 193 Answers
Lock the drill in a vise so you can work on it. Then try working a very small screw driver tip into the jaws as you at the same time back up the jaws. They may be jamed against each other.
Posted on Nov 22, 2008
How do I remove chuck on a dewalt right angle drill dw960?
Open the jaws and look inside. You'll see a fastener. Some have Phillips head or an allen wrench. Use the proper tool to turn the fastener counter clockwise to remove the fastener. You may have to help the chuck off the spindle if it sticks.
Feb 24, 2015 | Dewalt Drills
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
I can't get the teeth to close around the bit? It is stuck open any solutions?
Some chucks have a screw in side the chuck maybe a star-head it could be lose.
Feb 05, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
De Walt DW988 XRP 18v 1/2" Hammer Drill have
Depending on how much play, thats normal. The hammer feature causes that.
Jan 25, 2011 | Dewalt Drills
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
870 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
