Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony Memory Stick ProDuo Memory Problem
I have the Sony Cybershot DSC-W50 camera, and I use the 1GB Sony Memory Stick Pro Duo. I have had this memory stick for less than a year and it has always worked properly without any problems ever. I recently just deleted all of the pictures on the Memory Stick to make space for new photos, however when I went to take an actual picture, it says there is "no space in memory stick." When I go to review and see if there are any pictures remaining, it says "No file." I am really confused as to what has happened, I have never had this issue before. Is there any way for me to fix this?!
  • 1 more comment
  • crystalac3 Oct 16, 2008
    I'm not completely tech-savy, however I am not beyond help either.....any advice on how to format? Simple instructions would go a mile.... thank you so much!!
  • crystalac3 Oct 17, 2008
    Thank you this is very helpful. One thing....I'm a Mac girl......does this work the same?
    Nevermind-----I used my old PC laptop and did it, and it worked!!!! Thank you so much for all the advice!!!
  • 74 Answers
If you insert it into your pc and go to my computer right click on the icon for the drive that contains the stick select format and then follow the steps this should solve your problem.
Posted on Oct 17, 2008
PLEASE FORMAT AND SCAN IT TO REMOVE ANY THREATS
Posted on Oct 16, 2008
What size memory card does thedsc w50 use
The DSC-W50 uses Memory Stick Duos and Memory Stick PRO Duos, up to 2GB in size.
Sep 14, 2011 | Invisibleshield Sony Cybershot DSC-W50/W55...
Does a brand new right out of the package Sony memory stick pro duo require formatting before initial use in cybershot DSC-W50 camera?
There should be no need to format the card, just plug it straight in and snap a few photos...the camera will let you know if the card needs to be formatted
May 04, 2011 | Cameras
HOW CAN I REMOVE MEMORY CARD?
Hi There and Welcome to Fixya.
To remove/insert the memory stick pro duo from your Cybershot DSCW55, follow these steps :
  • Open the battery/memory stick duo cover
  • Remove the battery pack
  • Remove/insert the memory stick duo (insert with the terminal facing the camera lens)
  • Insert the battery pack and close the battery/memory stick duo cover
For more helpful information and details regarding usage and maintenance of this camera, please follow the below link :
Sony CyberShot
Pull up the website and simply click the "Instruction Manual".
Enjoy, and Thanks for using Fixya.
Apr 12, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Memory for Sony cybershot 4.1 DSC-P43
Hello Teena77,
Although I do not own this camera however according to the Camera manual's Page 113:
"Memory Stick PRO" with a capacity of up to 1GB is verified for this camera.
You can find the manual online at:
http://www.docs.sony.com/release/DSCP43.pdf
Please let me know if that works .. :)
Regards,
Srinivas
Apr 03, 2009 | Sony Cameras
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
Memory Stick Pro Duo 1GB
First try and clean the card slot. If this does not solve the problem, replace the memory card and try.
Dec 28, 2006 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
137 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
