Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Pro idiom IMP 1200 hook up
We bought 110 Panasonic th-42pr10u as well as pro-idiom IMP 1200 boards already installed. The hotel is wired with coaxial cable and it subscribes to Cox cable. Without having an HD digital box in each room. How can we provide each of the displays with a high definition picture and still use lodgenet while going through the Pro idiom board via A coaxial cable? I didn't see the correct model number TV below. However, I thought you might be able to steer me in the right direction if you don't happen to know the answer to my question. Thank you
my number is 858 459 4755 or e-mail is ccollins@san.rr.com mouse
This message is probably a year late but if your still looking for HD over standard coaxial cable to Panasonics IMP1200 media boards, the solution is ZeeVee. The new ZeeVee Pro250 looks very promising. Im about to use is in several local restaurants that currently have standard modulated signals. check them out at www.zeevee.com. You will need a Pro250 for each Cox HD cable box your running in the system.
Posted on Jul 18, 2009
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
I tried to reset button but still no sound
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Apr 19, 2015 | LG 32LD320H 32IN PRO IDIOM MPEG 4 TV SHINY...
How to change idiome on my scanner hi-pro
Hi Pierre,
IDIOME???, I have no idea what you are referring to here.
Could you pls re-post your query with full details of the issue you are having with your radio scanner.
Cheers,
Peter
Feb 10, 2013 | Radio Communications
Hdmi inputs dont work after lightening storm
Did you disconnect from power the units connected to the inputs? I would guess either the set or something hooked to those inputs got a static hit.
Oct 28, 2012 | Panasonic TH-42PX75U 42 in. Plasma HDTV
I bought a Panasonic 42" Plasma th-42pwd8 from a hotel. The monitor had the menu, and channel buttons disabled through "Hotel mode". It did not come with a remote. How do I unlock the buttons?
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
May 15, 2010 | Panasonic TH-42PWD8 42 in. EDTV-Ready...
Jenn-Air 30 in. Under Cabinet Hood had no instructions on how to
This is a straight forward wiring project involving 110 volts of electricity and a 15 amp circuit.
If there is already power available at this location use it. If not, run a wire to the cabinet above the hood location with enough extra to drop down into the hood area and hook it up.
Once you have the power wire in place it is just a matter of hooking the wires up black-black, white-white, ground-ground screw.
enjoy your new hood.
May 26, 2009 | Jenn-Air 30 in. Pro-Style Range Hood
Wiring for an Amana PTL
That is a stinger leg and you will burn the unit up. 2-@110/ground is what you need.
May 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
No power
if you have no power or lights flashing then you have to check your ac cord and ac supply this is the power socket itself if good then power supply board fuses after this check dg board be aware there high voltage and its dangerous to touch these circuts. if your not familiar with electronics and voltages. let a pro take a look at it and find the bad circut or fualty boards. hope this helps..
Apr 18, 2009 | Panasonic TH-50PX75U Plasma HDTV
Need assistance installing an RF Tuner module (IMP-1200) into a Panasonic TH-42PD50U Display. I understand that there is some configuration needed. Please help !
Unplug power to the monitor before you attempt to install the tuner module and the Imp-1200 must be physically installed in slots 2 and 3 on the monitor.
Once card is installed, power on the monitor and enter the setup menu. highlight the OSD option then press and hold the surround button on the remote. This will enter a set of new options go to the digital slot option on page 3 and select slot 2. You should be done.
Dec 05, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Windows Vista and Office Pro 2003
hi, yes you can install office 2003 while you already have office 2007. you just need to change the installation directory when you launch the setup for office 2003. change it into something apart from what office 2007 already is installed in. so what you're trying to say is that you should be entitled to an upgrade to office 2007 if office 2003 doesn't work? i would maybe think so... but no solid answer for that one.
Sep 09, 2007 | Microsoft Office Standard for PC
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
592 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
