I have horizontal lines on the top of gateway computer monitor, the blue line at the top is barely visible and the close, minimize, and restore buttons can not be seen, can this be easily fixed with a free download from somewhere. My computer is a 2002 model
  • 4,338 Answers
This could be one of two things:
It could be the monitor that is going bad. If it is, it would be best to replace it.
Second, It could be the Video board or the system memory. Which can be repaired.
If you have access to another monitor or a friend's system,try your computer on it. This will tell you whether it is the monitor or the computer.
Post the findings here, and we can continue to T/S it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 16, 2008
My monitor suddenly appear a 'dead line' horizontally..
anything can be repaired if you have the money and are willing to spend it. However it would be better to get a quote and weigh up the pros and cons of replacing it cheaper than the repair A new monitor wilol also have 3 years warranty ( Samsung)
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Gateway FPD2275W LCD Monitor
Line across middle of screen and series of lines below that overlaying whats active on the monitor. It's a new 23 inch acer
Your screen is made up of layers in which gas is trapped. whenever any side of the screen gets cracked it may not be visible with naked eye. The gas gets released and you get a horizontal straight line blue or black. Initially it starts with a thin line and as the gas releases it keeps on getting broader. If your acer is on warranty try to replace it or else you will have to replace it out of your own pocket.
Sep 07, 2009 | Computers & Internet
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Horizontal lines on my monitor
Lines on screens are usually caused by damage to the ribbons on the actual screen face itself (something only a few professional lcd repair shops can repair).
Sometimes caused by a bump, other times from over-wetting when cleaning, or dampness/moisture issues
The inverter-power board does Not control picture, It just controls the backlight bulbs and powering the video board.
Picture is powered from the video display board.
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Gateway EV730
Hello Jahodi
Happy Holidays
WHat kind of lines has it? from any program or it is directly from your monitor? may be is your monitor that has problems with horizontal lines, this happend sometimes.
try changing to the refresh rate to 75, or the size of the screen. to 1024 x 768
Dec 21, 2007 | Gateway 500 CS PC Desktop
Distorted white lines running across screen
Disconnect the monitor from the computer and turn the monitor on
it will display a diagnostic colorbar are the lines still there.
if not they are likely a cable or video card.
if they are still there have a tech evaluate the monitor.
Dec 21, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Screen problems
have you checked the cable between the base and monitor for a fault ie broken cable, lose conector as it sounds like a signal problem, common fault for alot of laptops with the screen being open and closed allot all my best ric
Oct 12, 2007 | Toshiba Satellite 1905-S277 Notebook
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Wavy Vertical Line
you have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Jun 26, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
