Question about Whirlpool LGR8648 Gas Dryer
Gas dryer tripping breaker when plugged in.
Whirlpool gas dryer wouldn't heat, but it would tumble and blow cold air.  I changed the heating element and two thermostats and now it immediately trips the breaker when plugged in.  The circuit is 20 amps, probably shared with a few receptacles, but nothing major.  No previous breaker trips.
Whirlpool gas dryer LGR8620PW0
ser - MR3405932   this model was not represented in the product selection, so I just selected something to push this through, sorry for any confusion and thanks for your help.
I have the same exact problem. Dryer works great....when empty. Put wet clothes in and 3 or 4 hours later they are as wet as when I started. I am going to kick the piece of junk to the curb and go get a GE dryer right now.....I suggest you do the same.
Posted on Oct 23, 2010
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
No heat gas kenmore gas dryer
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
Whirlpool lgr7648pq0 gas dryer no longer heating; just blowing air; no exhaust issues;
More than likely you have a burned up heating element. There is a remote possibility that you have a blown circuit breaker or fuse in your house. The blower is wired for and only requires 120 volts but the heater element requires 220 volt service. Usually there are two circuit breakers in your house breaker or fuse panel that provide power for the dryer. One of them may be tripped/blown and the other one may be ok..still on...and providing power to the blower. So...check to make sure there is not a blown fuse or circuit breaker tripped. This is the easy solution if it applies but probably the heating element is bad and will need replacing.
Sep 01, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool 29"gas dryer Model#LGN2000LW1
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 17, 2008 | Whirlpool GGQ8831L Gas Dryer
No heat
Heating element
Thermal fuse
Wiring
Nov 22, 2008 | Whirlpool GGQ8831L Gas Dryer
DRYER BLOWING COLD AIR-NOT HEATING UP
Heating element
Thermal fuse
Wiring
Nov 04, 2008 | Whirlpool LGR7646E Dryer
Estate gas dryer model#TGDX640JQ2 running no heat
Heating element
Thermal fuse
Wiring
Oct 26, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryer won't heat
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Gas dryer lgr 8648
Back in June I replaced the gas valve coils and that fixed the problem. It appears that when the coils are begining to fail, they'll work only when they are cold. After the dryer is up to full temperature the coils will not open the valve when more heat is needed...at least not until the dryer cools down.
I had this same problem with my furnace flame sensor. It failed in a way that it would only work when it was completely cooled down. Troubleshooting revealed that the furnace was failing at the 5 second "wait for flame sense". At that point the flame would go out and I could not restart it until everything cooled down. Thanks for all the help on this.
Jun 26, 2008 | Whirlpool LGR8648 Gas Dryer
Crosley cgdx563jq2 gas dryer
Heating element
Thermal fuse
Wiring
Oct 27, 2007 | Whirlpool GGW9250PL Gas Dryer
Whirlpool LGR8648 Gas Dryer Logo
252 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
