Question about Sylvania 6427TE 27" TV
Xbox I have a 6427T 27" TV when I hook it up to xbox 360 - and put the TV on game mode, it is all snow. I can't figure out how to get gaming mode to work. We tried other channels even.
I have the same problem with a 6420ff sylvania tv with a xbox 360. I plug the red white yellow into the front of the tv and it wont come on.
Posted on Oct 26, 2008
Im trying to hook up my xbox 360 to my digital lifestyles flat screen and cannot figure it out :((
A USE HDMI CABLE FROM XBOX TO TV AND SELECT HDMI AS THE IN PUT ON THE TV OR USE A HDMI TO AV CONVERTER AND PLUG AV PLUGS IN TV AND SELECT AV IN PUT ON TV
Jun 08, 2014 | Video Game Consoles & Games
How do you hook up a game system (xbox 360 ) to this tv
see on the remote contro you got option for TV/AV 1 and AV 2.and you shouldd enable the game mode
Apr 07, 2012 | Video Game Consoles & Games
Sound doesn't work while playing a game or movie from Xbox 360. It used to work - then it just stopped while a movie was playing. now games and movies won't play sound. Cables are good, sound sytem is...
You can figure out real quick through isolution what the problem is and who to point the finger at. Go ahead and unplug your xbox 360 system and hook it up to another tv. It doesn't have to be hdmi, just a standard one can work fine so you can plug the yellow video, and two white/red audio cables in to test. If that works then you need to look at the ports on your tv or sound system as the source problem. Check the settings...it doesn't hurt to reset them and reconfigure. Also check the xbox system settings in the Dashboard and verify. That will get the ball rolling and get your solution asap. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Console
I need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
Dec 27, 2008 | Microsoft Xbox 360 Console
Unable to switch to Aux in order to play xbox 360
http://books.jvcservice.com/Download/566962143/LCT1467-001A-A.pdf
at JVC Support Page , download owners manual , listed above , on page 35 , it appears you should press INPUT button and cycle thru TV / video 1 / video 2 / V2 component / and video .
depending what video input option you used to hook up your Xbox to , you should be able to figure it out from here.
Dec 26, 2008 | JVC TM-2703SU 27" TV
How to hook an xbox 360 to direct tv
What do you have coming out of the xbox 360, HDMI or RCA? The same question for the direct tv?
Apr 04, 2017 | Microsoft Xbox 360 Console
Xbox 360 game mode
Make sure your xbox is set to plain TV instead of HDTV. There is a switch on the cord that plugs directly into the back of the xbox.
Nov 08, 2008 | Symphonic ST420FF 20" TV
Can only get snow on tv screen
Try Changing the AV cable from HDTV to normal TV unless your TV is HD the cable Setting on HDTV will not work. You have to turn off the system and then change the switch. Then turn on your system.
If this doesnt fix your problem then Either of two things has happend your AV cable has gone bad or the chip that enables the AV cord inside the XBOX has bit the dust. If this is the case you will need to contact MS.
Jun 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
Sylvania 6427TE 27" TV Logo
699 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
