Question about HP Office Equipment & Supplies
Printer is offline. will not turn on. - HP Office Equipment & Supplies
There is no adapter in between, direct current to the printer.
Posted on Oct 17, 2008
  • 128 Answers
Check the power adaptor of your prnter if it has an output dc voltage
Posted on Oct 16, 2008
How to turn printer from offline to online
Often times the printer will show being offline if the computer wasn't turned on before the printer. Also, if you have more than one printer be sure the printer you are trying to use is selected in the printer setup page.
Aug 16, 2017 | Brother MFC 7860DW - Multifunction fax /...
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Trying to print 'offline'. Computer recognises it is offline but will not print. Error message says 'Printer is offline' which is as it should be. Printer is HP photosmart C4580.
So, if you want to print, the printer must be online. Offline method doesn't work to print. When the computer sayst that the printer is offline, it means ypur printer is turned off or you don't connected the printer to PC.
As in conclusion, if you want to print set the printer online.
Oct 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
Printer is offline
Press the most left button at the printer front panel.
May 06, 2009 | OKI Pacemark 3410 Matrix Printer
Ben Johnson
