Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite smart wash quiet pak 9 Front Load Washer
Error F 11 or dl and the signal beeps. When attempt to clear cycle, it will not shut off and door will not open and it will not restart cycle. I then try to clear cycle by unplugging from wall. When I replug it in, it still has previous cycle lit up. sometimes it will allow me to clear cycle at that point so I can open door. the error signal happens at different points during the cycle, It is not consistent. sometimes small amount of water in bottom. I try different cycles, like drain and spin to complete cycle, but no cycle finishes everytime
  • 1 more comment
  • kendra2325 Apr 06, 2009
    It is beeping with a flashing F H alter back and forth
  • eric268 Apr 13, 2009
    I am having the same problem, can't open door, I get dl error and F11 error. any ideas.
  • Mike M. Jun 17, 2013
    I hate my washer because of this. I don't suggest anyone buying the Kenmore Elite. Too "smart" for it's own good.
Our washer is flashing a F21 and it never finishes the load there is always water left.. what can we do to fix it?
Posted on Sep 06, 2010
    New Friend:
I've been fighting this for years. I regret having this washer. Sometimes, a good "pound" on the top will help. I don't suggest anyone buying this washer b/c of this. Too "smart" for it's own good.
Posted on Jun 17, 2013
F6
Posted on Mar 25, 2012
3 Suggested Answers
SOURCE: I have quiet pak 2 kenmore elite. It will not
i have the same problem right now today hope some one knows how to fix it ,, have cleaned out bottom hoses and catch pan nothing ..
Posted on Feb 17, 2010
michaelr1975
  • 33 Answers
SOURCE: I have a kenmore elite
it sounds like a bad sencor
Posted on Nov 10, 2010
I have a Kenmore Elite HE4T quietpak 9 washer. It has stopped the wash load with about 11 minutes left several times. It gives and error code DL then F alternating. The door remains locked and anytime...
The error you have is due to a failure in the door latch mechanism. There is a way to manually open the door if you are a little handy I can send you some instructions, it requires pulling the lower panel off (3 screws).
Let me know if you want me to help on this.
Phil
May 20, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
I have quiet pak 2 kenmore elite. It will not start and displays f dl
Feb 17, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elete 45862401 Quiet Pac2 front end washer that stops during the wash cycle. it flashes a f6 error code. The manual says it is a loose wire between the mcu and/or control panel,shipping...
With the front door open, see if you can rotate the basket freely.  If not, most likely the bearing of the rear tub is worn out.  You will have to replace the whole rear tub which is about $300 for the part.  I am having the same issue with my Kenmore Elite Quiet Pak 2.  I'm contemplating with just buy a new top-load washer.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Quiet Pak 4 front load washer. I keep getting the DL and F11 error. The door is locked and won't open and the cycle will not continue. I can hear a small clicking noise in the...
f11 eror is a serial coommunication error check the harness wirinbg tio the motor and cpu unit
check the drive system for worn part
check mcu motor the dl error fial code is for door lock error it will try to lock 6 times before error code is displayed that is the issue see repair clinic.com for help hope that helps
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite will not resume cycle
need more information any error code or stopped at 11 minutes/ possible f/11, dl/f its ccu board top in back
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
2,195 people viewed this question
Sal De
fordexpert
Robert Rankin
