Question about GE Profile JTP18 Electric Single Oven
Broiler comes on instead of oven
Error code "F2" after the oven was turned on but only the broiler operates.
Cleared the code, turned power off and on but still the same result.
  • tboe Oct 26, 2008
    Same deal here, any answer?
catriver
  • 878 Answers
SOURCE: F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Posted on Mar 04, 2007
SOURCE: F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Posted on Dec 26, 2007
  • 31 Answers
SOURCE: Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Posted on Jan 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: KENMRE OVEN BROILER SHOWED CODE e3-f2 AND BROILER
Your electronic oven control has failed.)ERC) It must be replaced.
Posted on Jul 07, 2009
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
KENMRE OVEN BROILER SHOWED CODE e3-f2 AND BROILER WILL NOT TURN OFF
Jul 07, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
What does f2 mean?
It is a oven temp too high code...check thrmeostat connection if ok, try unplugging or disconnecting power aprox. 1 min try again if F2 comes up again need to replace sensor
Feb 11, 2009 | Kenmore 47783 Electric Single Oven
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
What is F2?
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board. F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Nov 16, 2008 | Jenn-Air Ovens
hi there,
can you provide the model # off your stove please?
Sep 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F2 error code
Nov 18, 2006 | GE JGRP17 Gas Single Oven
GE Profile JTP18 Electric Single Oven Logo
140 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
