Question about ASUS (S370L) Processor Board
Asus iam using asus board and processer speed is good but iwant more speed iam using ram is 1GB how much i can upgrade my ram kindly give me solutation
  • 3 Answers
First of all you have to check your motherbord which type of ram
it may be ddr1 and ddr2
it support 4gb ram in this motherbord
look at the bus speed of ram
other wise it will promt less mb in
Posted on Oct 17, 2008
Hi
Well about guaranteed your 2 gigs ram is probably DDR II ram which has maximum of four gigs with 64 bit processing and 2 with 32 bit is. So motherboard needs upgrade. 35.00 for good giabit or board with 1000 megs a sec ethernet lan. With ddrIII ram. And upgrade operating system I believe win 8 has max 16 gig ram win 7 uses 8 gis vista and longhorn 64 use 4 and xp normal edition 32 bit uses 2 max. So you about have to run win 7 or 8. Win 7 will become direct x incomparable at some point making us change to win 8. Win8 cost like 300 to 350 and tiger direct.com has good deal of the win 7 pro media center for 75 bucks. So spend 150 on good speed 8 gig ram, 125 bucks for 12 core and at 4 GHz I think. And a board for 35. Reuse all other componets. And you\'ll have a 2500 dollar computer and best on the block. TigerDirect com Electronics Tablets Phones Office Supplies Video Games
May 16, 2014 | Video Game Consoles & Games
I upgraded my RAM memory adding an additional 1gb to another slot and earlier i was using 256mb.when i started to boot, my system just restarted after the windows loading process and this happened all the...
1) Check your BIOS to see if there is an AUTO spd setting. (usually you have to push either F2 or Delete key when you see the first black screen with white words)
2) Make sure that the speed ratings of the memory chips are compatible. If the new one isn't backward-compatible in speed, it might be too fast to be supported by an older motherboard.
Jul 29, 2011 | ASUS P4GE-MX Motherboard
I have a asus eeepc901sd with 1gb sdram; want to upgrade ram to 2 gb; is this possible?
Yes but please make sure you know what kind of RAM you need. (ie. DDR1, or DDR2)
Almost all laptops have atleast two RAM ports located on the back. I would advise contacting a licensed retailer to match up the RAM you need and give you a quote. Most laptop DDR2 1Gb of RAM prices around 40$.
Hope this helps ^^, Please don't forget to rate! Thanks :)
Oct 12, 2010 | ASUS EEE PC 901 Notebook
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Dear Sir i have pentium 4 motherboard 865gbx and i wanted to upgrade the ram. so maxixmum how much ram it will support and wat shd be speed like..333mhz??
IT supports Maximum 2GB DDR400 RAM.
It mainly depends on the Processor speed.I think 1gb RAM is sufficient for Your Pentium 4 configuration. If you use more than 1Gb.there is no remarkable speed difference between them.So better choice is use 1GB RAM.
Jun 24, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Ram upgradation for 845glad mother board
Hi! If you have orignal Intel D845 then you need ram less than 333 Mhz (Around 266mhz or so) and do remember to check that it is advisable not to use RAM of more than 1GB as you won't be able to find a 1GB RAM(DDR1) with 266 Mhz or less.
May 16, 2008 | Intel Motherboard
I want to upgrade Ram
yes there are different types of ram available but since u have a ddr 1 type of ram ddr2 wont match in ur maotherboard.and also do try to get the same type of ram available presently so u dont have problem with the clock speed.
May 12, 2008 | ASUS P5S800-VM Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
ASUS (S370L) Processor Board Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
