Unable to connect handset on brother mfc-885cw
Power went out and handset nolonger works unable to connect when using instructions in book just keeps coming up unable to connect
    Genius:
  • 2,120 Answers
Plug a regular phone into the wall jack and listen for a dial tone.
Posted on Oct 16, 2008
I purchased this machine mfc 885cw from someone their infor for wireless is in there and i do not know how to remove it. also i do not have the install cd
Go to the manufacturers website and download the installation and setup files. If you do a setup from scratch it will apply your settings and wipe out theirs.
May 23, 2016 | Brother MFC-885CW Used
I have a brother mfc 3360C fax and it gives me error message 50.How do I reset the machine.
How to the Reset Purge Counter on a Brother Printer (With a Numerical Pad)
The 'Unable to Clean: Machine Error 46? message prevents you from printing on your Brother inkjet printer. It is especially frustrating when you realise there no reason why you can't carry on printing other than this message. Continue reading to find out what makes me say this and how you can rid yourself of this error.
This guide will deal specifically with Brother inkjet printers that have a number pad on the front of the printer. If you printer has a touchscreen as well as a numerical pad please see here. If however your printer does not have a number pad at all, the guide found here should be of use.
What is Error 46? 'Error 46: Unable to Clean' indicates that your Brother printer believes the ink absorber in the base of your printer is saturated with ink and any further printing could cause ink to overflow. How full this waste ink tank is has been estimated by monitoring how many pages your Brother printer has produced and how many manual/automatic cleans have performed. Sadly this is not a particularly accurate method of measuring how full an ink absorber is and the majority of the time your printer could prints hundreds of pages before there was any danger of any ink escaping. However getting the waste ink tank changed and resetting the counter can be an expensive procedure if you get a service centre to do it on your behalf. In many cases owners of Brother inkjet printers report the cost of the procedure outweighs the value of their printer.
With this in mind we suggest resetting the purge counter of your Brother printer using the method described below and continuing to use it until waste ink begins to overflow inside/outside the printer. This ensures you get the most out of your printer and can avoid replacing it until it becomes necessary to do so. I do however recommend you protect any surfaces around the printer should you decide to reset the purge counter to save any surfaces becoming stained with printer ink.
What printers will this reset work with? This reset procedure should be compatible with almost any Brother inkjet printer with a numerical keypad on the printer itself (and not touchscreen panel) and has been tested on every current compatible printer at our disposal. You can find a full list of compatible printers below:
Brother MFC-210C, MFC-215C, MFC-3240C, MFC-3340CN, MFC-3342C, MFC-410CN, MFC-420CN, MFC-425CN, MFC-5440CN, MFC-5840CN, MFC-620CN, MFC-640CN, MFC-640CW, MFC-820CW, MFC-235C, MFC-260C, MFC-240C, MFC-3360C, MFC-440CN, MFC-465CN, MFC-5460CN, MFC-5860CN, MFC-660CN, MFC-665CW, MFC-680CN, MFC-845CW, MFC-885CW, MFC-250C, MFC-255CW, MFC-295CN, MFC-297C, MFC-490CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-990CW, MFC-J615W, MFC-J220, MFC-J265W, MFC-J410, MFC-J415W, MFC-J430W, MFC-J5910DW, MFC-J625DW, MFC-J6510DW, MFC-J6710D, MFC-J6710DW, MFC-J6910DW, MFC-J825DW
If you have a printer with a numerical pad not covered above and find the purge counter reset works for you then please let us know so we can update our list.
Video Guide Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
I hope you have found this guide useful. If however you have anything to add or any further questions please don't hesitate to let us know in the comments.
Jun 02, 2015 | Brother Office Equipment & Supplies
I connected my Brother MFC-210C printer to my old computer, which I used on there before, my printer is now saying unale to init see troubleshooting and routine maintenace chapter in user guide,...
just to go to google and type the product and stated user's manual..it will show all the link that you can download the manuals or try to contact the company then ask them if you can get some of the copy of the user'a manual of the printer.
Sep 19, 2011 | Brother MFC 210C All-In-One InkJet Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
I have a brother mfc-885cw and I dont knoe how to
You have to connect the machine to the computer using a USB cable and install the S/W you got with the machine from the CD. That will have a TWAIN driver and some scanning S/W you can use to scan a document in to the computer, then you can email it. Please see document called Software user guide on the disc. If you don't have the CD you can go to Brother website and download the manuals and the S/W.
Jan 25, 2010 | Brother Office Equipment & Supplies
I have a Brother MFC-885CW printer. A friend
I have a Brother MFC-885CW also and I have changed the colour inks no problem but now I have just changed the black it will not print black.
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Hi I would like to know if the mfc 885cw has an answerphone & how to set it. Thanks
The MFC 885CW does NOT have a built-in answerphone. It will connect to an external machine if you like.
Here is a link to the owners manual and if you like, you can download it. The section dealing with answerphone starts on page 55
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_685cw_885CW_EN_1339.PDF
Sep 22, 2009 | Office Equipment & Supplies
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Brother MFC-885CW Wireless keeps saying it's not connected to the computer yet it printed yesterday fine
hai ,salva,just finish to install mfc-885cw,wireless,when i try to install mfl-pro suite,at the end evething is fine except the printer,is not install.problemwith root directory of cd-rom.can you help please
Nov 13, 2008 | Brother Office Equipment & Supplies
70 people viewed this question
jasbo
jasbo
