Protection light comes on and goes off - Audio Players & Recorders
Have older Sony receiver. Turns on then light comes on says Protector.
Posted on May 20, 2009
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Its on protect mode how do i take it off?
Generally if your amplifier goes into protect, you have a bad ground.
Unhook your power wire from the battery and trace your ground wire to the chassis of the vehicle. Strip the paint from the ground location, Put the ground wire back on the grounding location. Tighten the ground wire down securely with no play and hook back up your power wire.
Other cases revolve around the RCA cables.
Unplug the RCA's and see if the protect light goes off.
Plug one in and see if the protect light comes on and then the other.
If the protect light comes on, you have bad patch cables. Replace them and see if your issue is resolved.
If the amplifier was shorted, the system board made have been damaged.
Jul 28, 2010 | Car Audio & Video
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Mxa422 protection
Outputs are fried. Try disconnecting your speakers and see if it still goes into protection mode. If it does then you A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
May 24, 2009 | Lanzar MXA422 Car Audio Amplifier
Protection light goes on and off
test subs you may have blown the voice coil
Jan 18, 2009 | Rockford Fosgate Punch P4004 Car Audio...
My sony xplod 1000w xm-1652z doesnt work anymore
First off, according to the manual, the protect light should be green. That's normal operation. If it is red, that's a problem.
If it does go red, disconnect all of the wiring to the amp except the +12V and ground. Short the remote connection to the +12V to force the amp on. If the protect light still lights red, the issue is inside the amp and will need repair. If the issue goes away, try reconnecting one wire at a time until the protect light goes red again.
Mar 23, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
271 people viewed this question
 Grubhead
Grubhead
