FixYa.com
Tags:
BenQ CD-ROM Drive
Benq X52 CD Rom Drive not working (by 2 users)
By Hart - usenet poster
I have lost the use of my CD Rom after re-installing Windows
98SE,
The other CD Rom is working O\K this is a Benq
CDRW 40/12/40 IDE Retail Burnproof.
Motherboard is a Soltek SL-75LIV,Socket A MATX S + Graphics.
I have now Installed Windows 2000 & still have the same problem.
Is this a Driver problem & if so how do I get over it?
All the plugs etc have been gently moved but no result.
Hoping you can help a Sweet old Lady in distress.
(Well I think I am)
Mary..
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 30, 2008
my cd rom not working
Best Solution
posted on May 28, 2006
FixYa! (100)
Luisa_K
Luisa_K - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Oh i can assure you i would have plenty to fill my time, there is never
enough time in the day, even if i don't use the pc at all to do everything i
want to do.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
You don't need a reliable system, if you had one you would have nothing to
do with your time.
Solution #3
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
No, i don't need to.
Solution #4
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
Because you don't have the confidence.
Solution #5
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
There are plenty of people who think the same, i'm not one of them though
Solution #6
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
*snip*
*snip*
Sorry for delay, been away!
Basically did a format and started from scratch (again) with a downloaded
boot disk.Not quite sure why this worked because I originally installed win
98 to a new hdd using the cd drive and all was ok, but then it suddenly
disappeared like I said showing up in bios and dos boot screens but not in
windows ! Any way my motto now is "When in doubt, format c: and start
again!" works for me. : )
Solution #7
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
No, unfortunately.
I was going to comment but decided to contact the poster directly to save
going through it again.
However the above may not be the best idea to try first in this case.
The first thing you should always check first is that the system bios can
see the drive, if not then nothing else will make it work, this can be seen
near the end of the POST (the last screen before the o/s starts to load and
can be held by hitting pause and then continued by pressing enter to allow
you time tio read it, it may also show up prior to this during Hard drive
detection depending on the bios settings.
If it does not show here then it is either knackered or disconected.
The second thing to do is to do a step by step boot to dos, by holding the
F8 key at bot to get the boot menu, check to see
if there is a cdrom driver being loaded and that two drive letters are
assigned, one to each cdrom drive.
Two things can happen here, if there is a driver and 2 letters are assigned
then it's a Windows problem and can probably be fixed by booting in safe
mode, removing any cdrom devices showing in device manager and rebooting.
The other is that no driver is loaded in dos, in which case my advice as you
posted above would apply, but first boot into safe mode and remove any
existing entries.
Solution #8
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
From the 'missing CD ROM post further down the page;
Locutus said
after a clean install of win 98 cd drive doesn't show up in windows my
computer, explorer or device manager its there in bios and shows up during
dos start up screens, also power light is on and flashes at start up.
swapped cd drive for one I know is in working order and same thing happens.
any ideas.
thanks for any help.
Grimley said
You need to install a dos cdrom driver to allow Windows to pick it up, once
Windows finds it the dos driver is removed.
Locutus said
Well thats me lost then, not too good with dos, go on talk me through it
Pleeeeease. ; )
There was a lot of name calling, and then Grimley said this
Download and install the acdrom driver from here (it's zipped so you'll need
winzip) :
Locutus said
thanx for help Grim got it sorted now.
But we never knew how :>)
Can you Help with these CD ROM Drives problems?
CD ROM Drives
cd rom for a206x
need cd rom for this model... Answer This...
CD ROM Drives
LG GDK 70
I am looking for LG GDK 70... Answer This...
CD ROM Drives
cdrom often lostii
i am having compaq presario... Answer This...
CD ROM Drives
cd drive
do you know thw dimensions for... Answer This...
CD ROM Drives
Message indicates the dvd drive...
I have a ccd-52X6D model star... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
