hello i m having problems with my sound and graphics.i have need for speed most wanted installed on my windows xp sp2.but it crashes after few minutes.when i had vista it was running fine.somebody told me that this is driver problem. i checked some of my driver files are not digitally signed.i m tired searching for latest drivers.plz help where can i get latest drivers.my system specifications are as follows:
System Information
Time of this report: 10/11/2008, 07:11:46
Machine name: SHERGILL
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: English (Regional Setting: English)
System Manufacturer: MICRO-STAR INTERNATIONAL CO., LTD
System Model: MS-7312
BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
Processor: AMD Sempron(tm) Processor 3000+, MMX, 3DNow, ~1.6GHz
Memory: 446MB RAM
Page File: 294MB used, 759MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file vtdisp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: The file viaudios.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: VIA/S3G UniChrome Pro IGP
Manufacturer: VIA/S3 Graphics, Inc.
Chip type: VIA/S3G UniChrome Pro IGP
DAC type: Internal
Device Key: EnumPCIVEN_1106&DEV_3108&SUBSYS_73121462&REV_01
Display Memory: 64.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: vtdisp.dll
Driver Version: 6.14.0010.0180 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/7/2004 11:07:54, 3325184 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: vtmini.sys
Mini VDD Date: 10/7/2004 11:08:02, 174592 bytes
Device Identifier: {D7B71FE6-7248-11CF-6677-1853A0C2CB35}
Vendor ID: 0x1106
Device ID: 0x3108
SubSys ID: 0x73121462
Revision ID: 0x0001
Revision ID: 0x0001
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: VIA AC'97 Audio (WAVE)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_1106&DEV_3059&SUBSYS_B0131462&REV_60
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: viaudios.sys
Driver Version: 6.14.0001.3870 (English)
WHQL Logo'd: No
Date and Size: 6/16/2003 11:05:40, 369920 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Standard
Cap Flags: 0xF5F
Min/Max Sample Rate: 48000, 48000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFF0
DirectMusic
DLS Path: C:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
VIA AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
que significa cuando dice windows drivers out of date
