Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
Heating element stays on after washing ends
This washer is about 4 years old and has recently developed a very bad habit of keeping the heating element on for hours at a time after a wash cycle has completed. This is despite the fact that "heat dry" and "high temperature wash" options were not selected. When the element is on and hot, the only indicator light that is lit is the "clean" light.
Dangerous problem not to mention wasting a lot of electro. Any clues? Common problem or a new one?
  • b-bean Dec 21, 2008
    I have the same problem, only with a Maytag that is three years old.
  • Frigidaire Master
  • 16,210 Answers
This is a serious issue that you should notify the manufacturer about and also the CPSC. With that aside, you need the repair manual and it is not free. You can order it online though. There is a high limit thermostat installed in the unit. That thermostat is supposed to stop any damage from overheating. The reason that it is overheating is due to a relay sticking shut. If you don't by the manual, you need to remove the unit from under the counter so you can trace wires. Get the color of the wires from the heating element and trace them back to the relay. It is possible the relay is mounted on a control board and those boards are not cheap and when I checked, they are not in stock either.
Posted on Jun 16, 2017
3 Suggested Answers
SOURCE: Frigidaire FDB635RBB heat wash/heat rinse
The "Safe Temp for house hold hot water is between 120 7 125 degrees. plenty good for washing dishes the high temp wash and rinse I've been told was put on the DW's to lessen first year repair calls under warranty. Thus the manufacturer saves lost of $$$ on service calls that just need the hot water temp raised on your hot water tank. DO NOT EXCEED 125 DEGREES WATER TEMP. OR HAVE A PROFESSIONAL REPAIR PERSON CHECK FOR THE PROPER HOT WATER TEMP. ALL YOU HAVE TO DO IS WASH YOUR DISHES NOT USING THE HIGH TEMP,. SETTINGS BUT MAKE SURE YOU DO USE THE HIGH TEMP DRY CYCLE AND YOUR GOOD TO GO HEALTH WISE. This information was told to me by a repairman in the business for 28 years. We have done it and it works just fine.
Posted on Oct 26, 2008
techbuster
  • 5081 Answers
SOURCE: Glasses have a film after washing complete. No
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
A helpful rating and a testimonial would be greatly appreciated if you are satisfied with my solution..
Posted on Oct 22, 2010
A "clean" load ends up
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 14, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
After the dishes are washed the inside of the door and bottom of the dishwasher are soiled and coated with grime. I end up washing the dishwasher. It is a Maytag Quietseries 300 and only about 18 months...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 23, 2010 | Dishwashers
Dishwasher is leaving a white film on dishes. Tried using less cascade. Washer is about 15 years old. Our water is in the safe zone for hardness, also its well water. Just started this recently.
heatman101 ..
Nov 06, 2010 | Dishwashers
8 year old maytag, clean lime build-up 2 times a year and all the spinning parts look clean and no wear but all of asudden the washer does not clean the dishes very well. Plenty of hot water, soap is...
In you case check the heating element first...
heatman101
Asker
Sep 23, 2010 | Maytag Dishwashers
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
Dishwasher
How to Buy
heatman101
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
I have a 5 year old frigidaire electrolux dishwasher that is leaving a grainy residue after a wash
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 18, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Dryer will not heating up. Only 5 years old
Two possible reasons:
1. The heating element or the temperature sensor is broken.
2. The exhaust vent is obstructed and needs to be cleaned.
Good luck.
Oct 01, 2009 | Frigidaire GLET1041A Top Load Stacked...
Diswasher doesnt clean and leaves
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
May 31, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Baumatic washing machine not heating (BTWM4)
ohm out the element if it shows no continuty then replace it
Mar 25, 2008 | Baumatic BTWM4 Front Load Washer
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
