Question about Technics SL-1200MK2 Turntable
Technics turntable distortion emisson
My technics 1200 MK2 has started to emit a low frequency distortion thru my mixer thru to my amp and out the speakers . I have try alot of things(try different needle heads and needles , tried different mixer and amp) as i have other turntables and mixers to test the stuff. Im guessin it has to do with either the tone arm or the rca's or ground wire. I was wondering if you have heard of this problem or have any suggestions. FYI---The turntable is about 8 years old.
  • urbanmixster May 15, 2009
    got the same problem when bass drops in the tunes
    the sound comes out distorted. I have checked the rcas and the ground and all are in place. any one solved this prolblem pls let me know
  • 515 Answers
More than likely your RCA cables are going bad, and will need to be replaced. Not the hardest self-repair, but you will need to have some soldering skills. In addition, caution should be taken when taking apart your turntable.
Check out the following videos for self-repair assistance on these wonderful DJ turntables.
If you think it's too much for you to do yourself, get some professional assistance. Shouldn't cost too much for repair.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
Technics 1210 mk2 humming
Hi, it needs to be earthed to your mixer or amp. Cheers john
Feb 03, 2013 | Technics SL-1200 Turntable
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
My technic sl 1200 is distorting. It is not the stylus or cartridge as i have swapped them and it still distorts. Any ideas?
Could be a couple of things. Could be the alignment, weighting, tracking or all of those causing this. It could be the gain structure on your mixer is not set and is too high. Maybe that the output of the cartridge is to high for standard mm inputs
Nov 04, 2011 | Technics SL-1200 Turntable
I have a technics 1200 mk5 and when i put a record on the volume is low no matter how high i pt it up in the mixer. When i use it with serato it works fine. What can be the problem?
Years ago, Radio Shack sold a turntable with the same problem. The fix was to purchase a pre-amp to go between the turntable and the tuner/amp. I think this had something to do with a magnetic vs. ceramic cartridge?
Dec 14, 2010 | Technics SL-1200 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
styluscity@gmail.com
May 10, 2010 | Technics SL-1200 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
- OPTiC
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
Poor low frequency
Nope, the circuit boards have nothing to do with transmitting frequencies. There are only 4 items on the Technics 1200 that transmit frequencies...
1) Stylus/Needle
2) Cartridge
3) Tonearm
4) RCA Cables/Leads
If you've already replaced 3 and 4, the problem lies with either 1 or 2. Or the RCA cables you replaced were not done properly, or you used poor quality cables. Double check the work.
- OPTiC.
www.djprolab.com
www.1200s.com
Sep 12, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK2 Turntable Logo
485 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
