Question about Singer 7422
The thread tension on my singer advance 7422 is to loose, and i move the thread tension dial to make it tighter but it doesnt make a difference. what can i do to fix this?
  • 3 more comments
  • stephaniel Oct 16, 2008
    it doesnt come with a bobbin case! :(
  • Anonymous Mar 22, 2014
    thread is stopping at the needle thread tension dial and not anywhere else - Singer 2404
  • Anonymous Mar 24, 2014
  • Anonymous Mar 26, 2014
    Singer 5417 C
  • Anonymous Mar 31, 2014
    Dial will not turn to tighten the looper tnions
Useful to check the spool and bobbin threading. If either is not threaded correctly, the fabric will pucker/thread will break/loops will appear on either side of the fabric. Easiest to do with machine manual open so as to follow the instructions. Easiest to check your threading each time you change threads by running a test seam on scrap fabric (I keep a large piece of scrap fabric folded in half just for this). More often than not, the problem is with threading. Check threading before you change tension dial or ajust screws. Otherwise, you'll have changed the tension and may still have threading problems. Good luck.
Posted on Oct 16, 2008
If you sewing machine has a bobbin case that come out, remove the case and there should be a screw on it. Tighten or loosen it. That may help
  • Renajarett Oct 16, 2008
    Sorry about that. How long have you had the machine? If it is still under warrent, I would take it in.
Singer advance7422 burst the tread
When you thread the top do it with the foot in the up position. As you thread you should notice the ease of movement through the tension, holes, etc. If you come to a point it is sticking, check why. The tension could be a problem. Anyway, if you don't seem to have a problem hear then put your foot down. Pull on the thread to see if it is stuck or not moving with an extreme amount of difficulty. You may need to lower the tension. A good starting point is 3. I expect your tension is the problem. If it is still the problem then lower the bobbin tension slightly. By the time you finish the knot should be in the middle of the fabric. Sometimes there is one more problem It is the thread is poor quality and is unravelling in the needle hole. Observe this closely as you sew. You know what to do if this is the problem.
Dec 25, 2014 | Singer Advance 7422 Electronic Sewing...
My Singer XL 6000 upper thread is too tight and keeps breaking, when the presser foot is up the upper thread is loose, but when the presser foot is lowered the threah gets too tight, what I notice is that...
You need to loosen the tension on the machine. There is a dial that has numbers on it. The higher the dial is set, the tighter the tension is. Turn the dial to the left one number. Then try it. Do it over and over. Do not turn the dial all the way down or you will mess up your machine. Do it slowly, one number at a time and try the machine between dials.
Dec 22, 2014 | Singer Sewing Machines
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Spool thread bunches up on bottom on singer 6423
It sounds like the tension for the top thread is too loose. Try re-threading the machine, and then adjusting the tension to make it tighter.
Feb 24, 2013 | Singer 6423 Sewing Machine
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
My singer touch & sew has a problem with thread tension right now...help! Loops are large underneath - I've tried moving the thread tension tighter, then noticed that the screw holding the bobbin was...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 03, 2009 | Singer CE-200 Quantum Futura Computerized...
Bobbin tension is too loose
Dec 08, 2008 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7422 Logo
241 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
