Question about Whirlpool ED2FHEXN Side by Side Refrigerator
HOW TO GET TO THE WATER HOSE INSIDE DOOR. ED5FHGXXKQOO
MY WATER HOSE CRAMBLED DOWN TO TE OUT LET HOW DO I GET MORE HOSE TO GET MY WATER BACK..DOES THE DOOR COME APART TO GET TO THE INSIDE WHERE THE HOSE GOES
  • 120 Answers
What brand is it give the model number and brand if is a frigidaire sorry but no there is no fix the hose is insulated inside door
Posted on Oct 16, 2008
Water runs down the inside back of the unit and freezes
Our fridge has a plastic hose running down the rear of the fridge and water was coming inside and running down inside the fridge walls and out the bottom of the door when we opened it. I called a repair man and he blew the plastic hose out and reinstalled it and had no trouble since. Our fridge has a water tray under neath the fridge that this hose is suppose to run into. The tray dries itself out so you don't have to empty it.
Mar 20, 2015 | Refrigerators
Water leaking out front
Take the front door cover off use a Phillip screwdriver, screws are around the edge on the inside. Be careful the SS is pretty thin and you don't want to bend or dent it. What I found was a little rubber hose that connected to the top of the plastic air duct work and ran down back into the tub. This hose was restricted causing water to back up and then leak down the duct work on to the floor. Solution is to remove the hose from the plastic duct work,blow the hose out to remove the obstruction and reattach the hose.
Dec 10, 2011 | LG LDS4821ST Stainless Steel 24 in....
RE: whirlpool refrigerator side by side ED25RFXFW01. I accidentally severed the water line inside the freezer door. How do I get to it? It appears that the shelves and insulation are glued to the door,...
The water line can be replaced by removing the dispenser cover and disconnecting the tubing and then pull the old line down from the bottom hinge area. once out, you can install your new line back up into the place it came out of. it goes through a channel inside the door. once back up in dispenser area..connect back to nozzle. the hose under freezer door needs to be connected as well...
Feb 03, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Maytag side by side has frost that develops on freezer side
almost deffinately door seal.try hot cloth to warm seal and pull into shape ,close door ,if you look down seal it should stick to door frame all round.no air leaks...
Feb 11, 2010 | Refrigerators
ONLY TAKES HOT WATER, AND IT FILL UP TO HALF OF CAPACITY
Clean the intake screen out on the cold water side of hose. it's insdie te hose or the valve and looks like a scrren door material and is coned shapped.
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
My 316 bmw se has water everywhere!!!
Sounds like a head gasket or a crack in the head/block. Try some block seal from the local parts store, sometimes it works well.
Sep 07, 2009 | 1997 BMW 318
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water left standing inside the buttom of dishwasher
It depends on What kind of Dishwasher you have. If the pump is old it may very well be bad or it could be a drain hose routing issue. The drain hoseshould always be looped up in the cabinet under the sink. If the drain hose is laid down low, the water could be backing up from the hose back into the dishwasher.
Feb 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Soap dispenser overflows and leaks onto floor
ive seen that somehow somehting gets down inside the dispensor itself, ( fabric sheet, wash cloth, pull tab from bew detergent, and if this happens it gets down inside he fill tube blocking off te waterform entering machine and backs up through the front. by removing hte top of machine (3 screws across the back) youll see the dispensor box located in left front corner, look for the hose on the bottom leading to the front of the tub assy and look inside for debris
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front loading washing machine is having leakage problem
You need to work out where the water is coming from, either the front, back left or right hand side to give you an idea what/where to look.
Front - Open the door and check the door seal (usually grey rubber round the door) look for splits, chaffing, damage.
Rear - check the connection to the pump, there will be a (Black) rubber hose from the drum housing about 12-18"long, check for splits, connection etc.
Check and remove the pump itself, Isolate the electricity, to remove - disconnect the outlet hose from below the sink or upstand, lower the outlet hose to the floor and syphon off the water into a bowl from the machine, there will be some even if the machine appears empty. disconnect the plug on the pump (2 wires), disconnect the hoses from the pump (2 off) and check inside the hoses, bra wires, socks etc. look inside the pump for foreign objects, the pump can be wasily split open via 3 screws normally, refit in reverse order.
Top - remove the top cover usually 2 screws at back or side and will slide slightly to remove, check hoses to drawer and the hose below drawer to top of the drum housing, check the inlet solenoids at the back (where the water hoses connect).
hope this helps
Apr 08, 2008 | Washing Machines
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
95 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
