Question about LG DLE5977 Electric Dryer
LG DRYER MAKING CLUNKING NOISE
We have a 2006 LG Model DLE5977W that is making a clunking noise when it runs. We tried it with different size loads, as well as with no load in it at all. It seems to dry ok but we're nervous this might become something worse. Please Help!
  • 7 more comments
  • goldenwrench Nov 15, 2008
    I have the same problem on the same model number. Noise sounds like it's coming from the belt drive area under the drum. How do I gain access to this area?
    OOPS! MNTECH was 100% right! Drum is cracked. This is a 2 year old machine. I am now going to talk to LG about this obvious defect. See if they will cover it under warranty.
  • Anonymous Nov 30, 2008
    Mine sounds like it is starting to go. I am trying to access interior to check it out.
  • floabs00 Dec 06, 2008
    I have the exact same problem a cracked drum is this not a recall of some kind?
  • Anonymous Jan 23, 2009
    Same problem, but goes away when it heats up. I think the metal they used it too thin and likely warps when it cools. Mine is out of warranty but I agree that this is a defect and should be covered regardless of expiration date.
  • Anonymous Jan 26, 2009
    I have the same model, and it is 2 years 6 months old broke over the weekend. Just contacted Home Depot extended guaranty department.
  • Anonymous Jan 28, 2009
    MNTECH nailed it! I also have a cracked drum. Glad I read this before attempting to disassemble.
  • rhp123 Jan 28, 2009
    MNTECH nailed it! Mine was making a clunking noise too. As suggested, I checked the drum and it IS cracked at the seam in the rear. Thanks MNTECH!
  • Anonymous Mar 23, 2014
    The Dry Level button won't respond when I press More Dry?
  • 1,543 Answers
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Posted on Oct 16, 2008
I removed the filter in the dryer, now my dryer in making a bad noise..what should i do
Posted on Dec 23, 2010
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Spin
What kind of noise was it making. Squeaking? Clanking/clunking? Jet engine loud?
Nov 13, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
LG DLE5977 Electric Dryer Logo
1,708 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
