Question about Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard
Need to add SATA controller driver
Brand new Seagate Barracuda 7200.10 250Gb drive is not detected in the BIOS. I think i need a SATA controller driver but not sure. Any help is appreciated. Thanks, V
  • voyager99 Oct 16, 2008
    thanks for your prompt reply map. I downloaded the SATA/RAID driver (VIA RAID tool) and this program detects the SATA drive, says its good to go, but the drive doesnt seem to have a letter or show up in winxp explorer. Is there still hope? Thanks in advance. V
    President:
  • 2,351 Answers
Hi voyager99,
You can download the driver, (VIA 8237 SATA/RAID driver) from PC Chips but I doupt it will help.
If your bios did no see the 250GB drive than the onboard SATA controller is defective. This can not be fixed.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=305&DetailName=Driver&MenuID=1&LanID=0
Running the SATA/RAID driver will most likely not help the bios see your drive.
Buying a PCI serial SATA controller card may allow your SATA drive run but it will run at the PCI bus speed. A decent controll card may cost as much as a new board that will run your current devices.
Mike
Posted on Oct 16, 2008
  • Mike Peluso
    Mike Peluso Oct 16, 2008
    Hi voyager99,
    I can see where you may think, "Wow this is working"!
    I so hate this bad news stuff!
    Windows will not assign a drive letter because it can only see what the bios see's. The RAID software is just that! Software. For IDE's, CD-ROM's, DVD writers / players, serial ATA SATA drives & other hard-wired motherboard devices, the bios is king. The Seagate drive must be seen in the bios. You can try another rout. Keep in mind though when you finish this new rout if the bios still does not list your SATA drive the game is over.
    Please go to Seagate's web site: http://www.seagate.com/www/en-us/support...
    Start off by downloading, Download SeaTools for DOS now! This will allow you to create a bootable floppy disk. See the tutorial on the usage of SeaTools for DOS. If this program fails to see your SATA drive we are back to the SATA controller on the board.
    You are not the first person that has come across this. Every manufacture has a few boards that fail with respect to the onboard SATA controller. Even me! So I have first hand experience with defective SATA controllers. You can click start & open run, type in diskmgmt.msc & click ok. Windows disk management program will load. I'll bet the Seagate drive is not shown.
    Your board is out of warranty. Replacing the board is the only option, unless you are happy to run IDE drives. Seagate drives come with a five year warranty. So there is plenty of time to continue using just IDEs.
    Here is a link for a PCI SATA controller: http://tekgems.com/Products/bt-pci-sata-...
    http://www.govistashop.com/catalog/produ...
    As you can see some of these controllers are anything but cheep.
    http://www.google.com/products?hl=en&...
    As I mentioned, it would be cost effective to replace your current motherboard if you intend to use serial ATA SATA drives.
    Lastly, if you include all your current devices connected to the PC Chips motherboard & an idea of what you would like to run in the future. I'll look for a motherboard to accommodate your current CPU, memory & specs.
    Mike
Describe your Seagate Barracuda 7200.12 500 GB SATA Hard Drive is not getting detected in BIOS
It requires special hard ware tools to solve this problem. they are available with me and it just takes 20 minutes to get your data back. this is called LBA ZERO REPAIR, AND TRANSLATOR REGENERATION.
Nov 22, 2010 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Cannot detect Seagate Barracuda 7200.9
The motherboard has two SATA connectors but they only go up to a 150 MB/s data transfer rate.
Your Seagate however, is engineered for 300 MB/s data transfer.
Download the Seagate manual for this drive and you will see the diagram on the last page that shows how to place a jumper on the drive to make it work at 150 MB/s.
Mar 21, 2010 | EPoX EP-8HDAI PRO VIA K8T800 CHIPSET...
How can i fix my seagate HDD,it wont detect in bios boot up..
Make sure it is connected to power and SATA, try a different SATA connector on your motherboard, there are probably 4 different connectors. Also make sure that the SATA controller is set to "NON RAID" mode in bios.
You need to go into BIOS to change these settings, If you don't know how to do it Give me your motherboard details (model no makers name)and I'll write you out a walkthrough to set the bios up properly for your drive
Jan 25, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
The hard drive i have is not being detected i was wondering if i needed a driver or something...its a seagate barracuda 7200.10 500Gbytes
Is the drive being detected in BIOS but not windows or does it not show up in either? You do not need a driver for hard drives, so I'm assuming either the drive is faulty or it just hasn't been initialized yet. Reply back and I will assist you with either issue.
Chris
Sep 24, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
May 22, 2009 | Seagate Barracuda 40 GB Hard Drive
Harddrive is not detecting bios
get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk drive not deteted during windows installation
This problem arises due to a missing driver in windows installation. download your specific driver and copy it to a floppy drive. Then start the windows setup. As the setup loads it will ask "Press F6 to load a SATA RAID driver".Press F6 and insert the floppy into Floppy disk drive.
And continue the setup...
Jul 16, 2008 | Computers & Internet
Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard Logo
994 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
