Question about Frigidaire CWS3600AS Top Load Washer
Washer does not engage in spin cycle
Pulleys will move freely by hand but seem to lock up mechanically.will not spin
  • liamleee Oct 16, 2008
    this is a frigidaire crown series top loader
  • Anonymous Mar 07, 2009
    the Belt around the gear box gets hot a and smells like burnt rubber the belt turns freely
  • 958 Answers
Could be a stuck gear box. this gear box could have a mechanical problem on the spin cycle.
it usually turns the reverse rotation if it wants to spin.
check the pulley of the gear box, rotate it in one direction for twenty revolutions. see if it agitates. then next turn it on the other direction and observe if it is binding or stuck.
if you can remove the gear box and check the mechanical gears inside, maybe you can find the problem and replace the part.
tnx 4 using fixya,
drcool
Posted on Oct 18, 2008
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Maytag Performa Washer...It will fill with water but will not move through the cycles...it simply sits full of water and you can hear a humming noise and a smell possibly like rubber. A friend...
sounds like either you have a stuck pulley or pump remove water with shop vac and tilt washer against wall get under washer remove belt spin small pulley by hand does the pump pulley move all directions freely if not something stuck in pump or is belt melted or worn out
Jan 27, 2011 | Washing Machines
I tried washing a rug - I believe it was too heavy and moved the washer around during the spin cycle. Now it is not spinning, it make the sound but it won't turn - I can move the tub around with my hand...
Hello- First unplug the washer. The out-of-balance switch may have gotten tripped. If you open the lid and look in the space between the tub and the top in the rear right corner you should see a plastic "arm" sticking down, reach you hand back there and move it back away from the tub. This lever actuates a switch in the control panel that will prevent it from spinning if there is pressure on it, it should be hanging freely away from the tub. Plug the machine back in and test it. If it doesn't work another thing that may be happening is the tub is not engaging on the transmission. With the tub empty reach inside the top perimeter of the tub and lift it up and let it down a few times, sometimes this will reset it and get it to spin. Lastly, i would check that the lid is locking when you put it into spin, the lid lock light should come on and you should not be able to lift the lid. If the lid is not locking you may need to have a F/P Tech out to replace the lid lock. You can test the spin by setting the machine to Permanent Press and advancing the cycle to spin. It will take a few minutes to start spinning usually. Let me know what you discover, good luck. Best regards.
Sep 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
FWS6600ES1 washer won't spin at all
I would expect there to be an allen screw in the pulley which bears on a flat spot on the shaft. The screw is likely loose or missing.
Charlie
Sep 13, 2009 | Washing Machines
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Everything works with the washer except the spin cycle. Its like the brake is locked. All the belts are good. What is causing the spin cycle not to spin? I have tried running the spin cycle and turning the...
try tipping unit over, theres a large pulley under there connected to transmission, grab hold and spin that both ways. one way free spins, the other way pushes up on the center shaft to release brake and start spin.you can replace the thrust bearing yourself( kit includes new pulley ,and cam w/ new spacers) a brake issue would need to be done by pro. you need special brake tools.
Mar 11, 2008 | Washing Machines
Washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Nov 03, 2007 | Maytag Atlantis MAV6000 Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
199 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
