Question about HP Computers & Internet
My hp 500 screen blank
Hp 50000
    Sergeant:
  • 306 Answers
The first thing to do is connect an external monitor to the external video connector since you can't troubleshoot what you can't see. If you aren't sure of whether your computer has started you can press the CAPS Lock key off and on to see if the indicator lights up. If the external monitor displays for you then use your Fn keys to switch between external and internal monitor. Control Panel's Device Manager will tell you if there is a monitor or video card fault. If the external monitor doesn't work then internal video adaptor is disconnected or dead. Another option is to connect your S3 video to a TV or DVD player. Some typical faults are a burned out CCD bulb in the LCD module, a ribbon connector bad or disconnected from the mobo to the LCD and a motherboard fried from spilling your drink onto the keyboard. Opening the the laptop is bad juju if you aren't qualified to put it back together but you can get service procedures if the computer is out of warranty and care to try.
Posted on Oct 16, 2008
  • anony-mouse3 Dec 10, 2010
    There seems to be a common hardware problem with this model. The screen will be blank until the lid switch (back/left near the ESC key) is momentarily pressed. The internal video will come on for about a quarter of a second and then go blank again. There doesn't appear to be anything physically wrong in the switch area nor with the switch connected to the motherboard. The driver is fine, the display adapter status reads OK. Bending/twisting the video itself, the motherboard, the power cable do not help. The only thing that momentarily works is pushing down on the lid switch.
    All you can do is to have the motherboard replaced or simply use an external monitor and leave it docked somewhere like this for good.
Since upgrading to windows 10 the printer takes ages to print, usually sends out a blank page first and more often than not an error message appears on the laptop to say the printer cannot print
electronics have what is called manufacturers specification upgrading may seem ok but the drive n kind of system may not match the specs this affects the normal working of the upgraded system just buy a windows 10 pc n all will be well
Oct 03, 2015 | HP Laserjet P2055 Printer Laserjet 1200 X...
If on a certain flexible pavement, there is a pressure of 100 psi along with a loding of 50000lb. can u please tell me how to go about and calculate average pressure or what to do with the loading...
I'd assume that this meant 50000 lb load causes an overall (average) pressure of 100 psi, and so the area (not originally given) is
50000 / 100 = 500 sq in = 500 / 144 = 3.47 sq ft
It is not possible to figure the average pressure from your data (if it isn't 100 psi) as the area is not given.
Sep 17, 2013 | Computers & Internet
I have done a factory reset on my HP Pavillion slimline and keep getting blank screen?
Hmmmm... nice detailed desktop!
But u failed to mentin ur MONiTOR?
Wut is it? CRT, LCD, monochrome?
Dec 04, 2010 | HP Pavilion Slimline s3407c Desktop,...
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
My hp pavilion slimline s3407c locked up and I
► do a power drain i.e unplug the power cable and press the power button and hold it down for 10 secs.
► reseat the hard drive by unplugging the cable connecting the hard drive and motherboard and also the power cable
Feb 08, 2010 | HP Pavilion Slimline s3407c Desktop,...
Palm Centro. got it wet. screen is blank on start up.
Contact nearest Mobile service center immediately.They will repair it or else they will replace some minor damaged parts if any.
Sep 09, 2009 | Palm Treo 500 Centro
Replase your transfert belt
The transfer belt is considered a consumable which means you need to replace it, it has a life expectancey of 50000 black only pages or 12500 coloured pages.
More info
http://www.retrevo.com/r/259dj079/50/Replacing+the+Transfer+Belt#q=Samsung+CLP-500
Sep 08, 2009 | Samsung CLP-500 Laser Printer
Blank screen after turning on won't allow reset
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status.
Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Aug 04, 2009 | Canon PowerShot SD100 / IXUS II Digital...
HP Pavilion s3407c, F11 key fail to startup system recovery
windows corrupted maybe try to reformat your pc and install back windows.but dont forget to take out your hardisk and backup your important things ok
Jun 06, 2009 | HP Pavilion Slimline s3407c Desktop,...
Configure NAND on Start up
I finally wound up deleating the base map useing the Maintenance codes, which has now left me with another problem and that How do you rload the basemaps from Mapsend Lite?
Stewart
Mar 16, 2008 | Magellan eXplorist 500 GPS Receiver
Computers & Internet Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
