Question about Maytag HYE3658AY Electric Dryer
Maytag performa dryer PYE2300AZW
My dryer has been overheating. I checked the fuses, the thermostat, and the heating element. All the components have continuity.
I tested the leads going to the heating elements. When i put on the heat their is 120V going through the heating element and 22 Amperes going through the heating element.
The power seems to be ok, but can the motor still be causing the heating element to overheat. What test can i do to properly test the motor?
Or can it still be another problem other then other components that i checked.
My dryer was working perfectly fine, but I think i had way too much laundry this day. anyhow, it just stopped working. the weird thing is the timer still runs I turn it to 90 and then it stops at 0. WEIRD!! i had my dad and husband take it apart, but of course we are reading the blueprints and tring to find matching numbers but no can do. we give up. HELP
sign the Dryer Monster
Posted on Dec 30, 2009
    Scholar:
  • 157 Answers
Hello humberguy. From the description noteing voltage & amprege( unit not 220v) I suggest checking the air intake & excaust. duckng. A preventive maintance maybe in need. A PM would be taking the unit to a air compressor and using a hand held air gun to blow the insides out. In the drum are wings, on the out side are pluds in the drum aligned with the wings, remove the wing and remve the cloth balls. I advise you wear a mask over your face it will be dusty. Good luck & let me know if this solved the problem.
Posted on Oct 16, 2008
My Maytag Performa dryer is not heating at all .What should i do? Everything else works it just doesnt heat.
Hi
Replace the thermal fuse, and if possible test the heating group (thermostats and element or gas heater). You can replace the fuse straight away, or you can first test it using a multimeter set on OHMS. If the multimeter reads Ohms infinity when you touch the fuse contacts with its probes, then the fuse is gone.
If the fuse is OK, then you can have a defective thermostat or heating element (electric models), with gas models you test coils, thermostats and ignitor (flame sensor rarely fails).
After fixing the problem clean lint from air ducts, if the thermal fuse or thermostat has blown it means that there had been overheating.
May 09, 2011 | Maytag Dryers
MY pye2300azw maytag dryer does not seem to be heating hot enough. can you suggest a solution please. Does it need a new thermostat, nothing wrong with the heating element.
Number 10 is the most likely suspect. The blower wheel tends to get wobbled out and won't send enough heat through the drum making it take twice as long to dry the clothes.themobilian_13.jpgthemobilian_14.jpgthemobilian_15.jpgthemobilian_16.jpgthemobilian_17.jpg
MORE HERE
Nov 02, 2010 | Maytag PYE4558A Electric Dryer
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
Will not start
it is likely the Thermal Fuse, LA 1053 kit for Performa Electric Dryers. You have to open the case, remove the drum, Loose the back panel and remove the Heater element case. The Fusible Thermostat is on mounted on the side of the heating element case.
Feb 26, 2010 | Maytag Dryers
No heat (replaced heating element and another
It sounds like you replaced the heating element and the small thing you refer to was most likely the thermal fuse. If these are the components that you replaced, and if they are indeed good, the next thing to look at if the dryer is not heating up is the high limit thermostat. It is most likely faulty if the element and thermal fuse are good. Hope this helped and best wishes. Here is a picture of a thermal fuse and high limit thermostat to help you figure out what is what.
Jul 30, 2009 | Dryers
Dryer element won't get hot
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Apr 02, 2009 | Maytag PYE2300AY Electric Dryer
No power to dryer was working fine no warning would not start
Most likely a bad fuse. There is one above the heat element, also may have one on the blower housing. Test with an ohmmeter or bypass. Hope this helps!
Feb 16, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Pye2000ayw won't turn on-tried taping wires
If your dyrer has a thermal fuse, it will be on the blower housing (front), not on the heat element. It will be either white plastic os a button about half the size of other thermos. The fuse on the heat element will shut down the haet only. Hope this helps!
Jan 04, 2009 | Maytag HYE3658AY Electric Dryer
Dryer will not turn on
i've had my maytag dryer since 2002. it just stopped in the middle of a cycle. i think it's the motor. isn't maytag guaranteed for life???
Dec 22, 2007 | Maytag Dryers
Maytag HYE3658AY Electric Dryer Logo
759 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
