Question about Ace Hardware MN180HPA Wall Mounted Panel Heater
PRO-COM MN180HPA Heater- Ceramic Panels not "heating"
We have three of these units in our home. One still works very well but two of them have had a problem. One of the panels on each is not heating. It is almost like the flames are not reaching the ceramic. Can I service my own heaters and if so how can i fix this problem. Or do i have to call a professional
  • 193 Answers
You would need to replace the complete burner,call a sevice tech
Posted on Sep 29, 2009
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
How to replace the cement-like substance between the panels?
You'll need to go to a specialist heating supplies store to get the panels. So take make and model details with you. They can probably give you some advice on how to remove the old panels.
Jul 16, 2015 | Heating & Cooling
Model mn180hpa pro com natural gas wall heater problem is flame is rising above in the middle of the grid
turn down the heat selector
clean heater (shut off )and use compressed air to blow out dust
on burner and pilot
Jan 04, 2015 | Heating & Cooling
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
Panel won't hold a flame
this could have to do with the main gas feeds to the ceramic panels . they might be obstructed with a spider web or dirt,foriegn material etc.
easiest fix is to take a air compresser with a blow gun tip and blow out ant foriegn material or spider webs from the gas feed pipes to
the ceramic burners.
the gas feed pipes have large air induction holes that a small blow gun can fit its nozzle into to blow out the gas feed pipes without
having to disassemble them.
that is a big time & work saver.
I took my gas feed lines to the ceramic burners all apart, only to get out a spider web that i could have blown out with compressed air and saved myself 2 hours work.
anything inside the gas feed pipes to the ceramic burners will result in dark spots or the panels not staying lite, irratic burning
or no burning at all.
the gas needs to be able to get through unimpeded at proper flow and proper pressure for proper burning.
a spider web will mess up proper gas flow. some gas, but not enough gas will get through and ceramic wont burn well and might not hold a flame.
clean out the foriegn material from the ceramic gas feed lines.
Rare posibility,if the gas behind the ceramic element escapes around the edges of the ceramic, through a bad seal of the gasket,
this also will stop the ceramic from burning well.
mr heater is not made for easy diaassembly so try not to do more work than you have to.
use compressed air rather than taking mr heater all apart to clean out a gas feed pipe.
Mar 26, 2011 | Mr. Heater Big Buddy Heater
On the side of the ceremic panels, a piece has fallen off and the gas/heat is "spitting" out. this happens on the high selection only. are there replacements for the ceremic tiles? I have a wall...
It's time to clean the interior of the heater and replace the ceramic plaques. You can order the plaques ( I would replace all of them) from Master Distributors http://www.vanguardheaters.com/ However, the number your listed is the Serial Number, not the Model Number. The Model Number is on the side of the heater or on some metal tags that are attached to it. It should say, DESA International - Vanguard and have the Model Number and Serial Number on it, along with other vital info about the heater.
Hope this helps solve your problem.
Mar 10, 2011 | Heating & Cooling
Pool heater recommendation
they make heat pump pool heaters. it works like an a/c but it heats. only uses electric. http://www.solardirect.com/pool_heaters/heat_pump_pool_heater/hpph.htm
also they have solar panels for pools. another good thing for a pool is a solar cover you just cover it when you are not using your pool.
May 29, 2010 | Jandy Lite2 LG400 Ceramic Compact Heater
Ace Hardware MN180HPA Wall Mounted Panel Heater Logo
67 people viewed this question
Top Ace Hardware Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
