Question about Toshiba Televison & Video
We have a Toshiba Portable DVD Player Model #SD-P101S. When the A/V output jack is inserted, the LCD monitor blanks out, and the signal goes to the remote projector. How can we disable or work around this, so the signal goes to the remote AND the LCD remains in operation?
  • 118 Answers
You will need a tv/AV splitter so that you can run both. These can be purchased for around $3 on Ebay or $15 at your local retail.
Posted on Oct 16, 2008
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
How to opperate the dvd player on a laptop toshiba satellite l500
depends on what kind of output jacks and input jacks are available on ur DVD player and notebook...as without proper jacks and correct cables u cant make a proper connection....DVD player Vs laptop
u also may need a connector or a convertor that can convert analog signal to a digital signal...also u may need a software to capture ur signal...google can help u
Jan 16, 2010 | Toshiba Satellite A135-S4527 Notebook
Sd-p2000 portable dvd player will not go on
dvd goes in spins says its loading that is all it does
Nov 13, 2009 | Toshiba SD-P2000 Portable DVD Player
DVD player lost charging power/only works with adapter plugged in
If you had the player for quite some time it could be the battery. The batteries eventually get weaker and weaker and go. Like laptop. Did you notice less usage time after you charged it when it worked?If it isnt that old it could be an internal problem you may have to get checked out by manufacturer, also check if its still under warranty.
Aug 15, 2009 | Toshiba SD-P101S Portable DVD Player with...
My toshiba portable dvd player (sd-p1900) won't play discs. We have two, and the other one works, so it's not the disc. When you put a disc in, it doesn't spin, and it says that there is no disc.
i had this same problem, its likely a disconnected ribbon wire off the drive, One I plugged that in it read/spun the disk, now I just need to get the screen to stop being blank white heh. Good luck ^^
Jul 14, 2009 | Toshiba SD-P1900 Portable DVD Player
Unlocking region code
Hi. Same problem re TOSHIBA portable DVD player bought in the USA, model SD-P91SKN. Wonder if anyone found the solution to unlock it to multi-region? Thanks!
Jun 25, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
Televison & Video Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
