Dryers Logo
James Sullivan Posted on Jan 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore #11066742500 dryer
Dryer, Kenmore #11066742500 dryer, fails to get hot enough even though coils are in very good shape and thermostat checked okay, no lint in vent or elsewhere, drum turns, etc. Coil is 230/240 volts and it is getting this voltage as circuit breaker checked okay] Could this problem be a relay, and if so where is it located? Any ideas? Where can I get a schematic?
Just Appliance Repairs
Level 2:
New Friend:
  • Expert 76 Answers
  • Posted on Jan 21, 2012
Expert
Level 2:
New Friend:
Answers
76
Questions
0
Helped
50632
Points
143
Could be several things. If it is a new hookup the neutral and one of the hot wires has been reversed. If it just started doing this the most probable is a shorted heating element. It will still test good on continuity test but part of it is touching the frame. The third thing is a bad thermostat, it would be cycling at too low a temperature. The temperature coming out of the exhaust should be between 150 and 175 at high heat.
1 Related Answer
Anonymous
  • 55 Answers
  • Posted on Jan 23, 2008
SOURCE: cloths dryer problem
ok " your dryer should have it's own line, make sure nothing else is pluged into that line.
may have other devices drawing amps.
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 • Dryers
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Dryer cuts off soon
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Thermal Fuse
Air Flow and Heat
Warning
I should like to have a Dutch or English user manual
Obstructed Vent
Your Kenmore dryer must be able to freely circulate air in the dryer in order for it to continuously supply hot air. If air flow is limited from a buildup of lint in the vent and lint tray, the high limit switch temporarily shuts off heat to the dryer. Empty the lint tray on the top of your dryer. Detach the exhaust vent -- the silver tube in the back of your dryer -- and thoroughly clean it out with a lint brush and reattach. Consult your Kenmore dryer manual for instructions on how to inspect and clean your vent hose. Once these components have been freed of lint, the dryer should dry clothes again.
Broken Blower Wheel or Belt
If you have completed a full inspection of your dryer vent system and found no obstructions, your dryer might have a defective blower wheel or belt. A failure of one or both of these components can restrict air flow in your dryer and take your dryer longer to dry clothes. According to Point and Click Appliance Repair, a noise coming from the dryer as the drum spins is usually an indication that the blower wheel is failing and needs to be replaced. Review your Kenmore dryer manual for instructions on how to locate these components on your dryer.
Faulty Thermostat
A broken thermostat can cause your dryer to produce too high or too low heat. Monitor the dryer exhaust temperature with a hand-held thermometer. The temperature should be below 150 degrees Fahrenheit. If the temperature reading is higher, then replace the thermostat. It's no longer able to regulate the temperature inside the dryer, and your dryer is in danger of overheating. If the temperature reading is room temperature and the dryer is running, the thermostat is broken and needs to be replaced.
Damaged Gas Valve Coils
Damaged gas valve coils permit your Kenmore gas dryer to ignite only once before coils must completely cool in order to reignite. This is a common issue among older dryers. If your dryer struggles to turn on or after it shuts off you must wait several minutes before it restarts, then the gas valve coil likely has worn. Confirm the location of the igniter from the manual. It's a cone-shaped tube that is located inside the dryer near the front panel close to the bottom. If the igniter radiates bright orange for 15 seconds without producing a flame, then the gas valve coils have probably failed.
2answers
TCO & HLtherm on Dryer
I think you've got your bases pretty well covered. I don't see a reason for you to replace the hi-limit as well. At less than an ohm, I see no reason to bother with it.
Top Dryers Experts
john h
