Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Top arm doesn't spin
No error codes and everything thing else works fine. Cleaned all arms too.
  • 423 Answers
It is important to know that the upscale LG diswashers alternate between washing the top and bottom rack. So it is normal for some arm to not be turning at certain times.
Also, if this dishwasher is set to half load, bottom only, the top arm will never turn.
Posted on Mar 28, 2009
Neither the upper or lower wash arms spin.
Circulation pump might be faulty. or spray arms are blocked. remove spray arms and clean them and try it again.
Mar 15, 2014 | KitchenAid 24 in. KUDP01DL Built-in...
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher is not cleaning well. The middle spray arm is not turning and I can't figure out why. I'm not sure if this is the problem. I cleaned everything down to the chopper assembly which is...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 06, 2011 | Dishwashers
The top rack is poorly cleaned once cycle is complete and middle sprayer arm does not appear to be circulating. Water comes from the top spray arm fine.
heatman101
Mar 23, 2011 | Dishwashers
I have a Whirlpool GU2455.... dishwasher. Top spray arm is not spinning. Lower arm appears to be moving but slowly. Dishes on the top rack do not get cleaned. They are wetted, but the arm doesn't appear to...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
heatman101
Jan 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Arms are not spinning
Hello there:
Here is a few things to try ok?
Make sure all spray arm holes, top and bottom, are clear of foreign matter. Does the bottom spray arm turn freely by hand or does it bind? Check under the bottom spray arm to see if the seal (split ring) or the bearing is worn. Check all other seals in the filter system and impellers closely for any wear for if they are swollen. If everything checks out OK and you have lots of water in the unit and the motor is running you should be good to go.
Hope that this is very helpfull for you
Best regards Michael
Nov 12, 2009 | Dishwashers
Kenmore Dishwasher Not Cleaning
heatman101
k;kjguit
Jul 31, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
161 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
