Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Panasonic PT-50DL54J DLP TV Flashing Light
Have a Panasonic PT-50DL54J DLP TV. Purchased in 2004. Power light flashes different codes (red). Have to unplug to get to reset. Some time ago lamp light also flashed, so replaced lamp. Lamp light no longer coming on but unit shuts down and power light flashes red. Have seen it flash 3, 4, 5, 6, 7 and 8 times since lamp was replaced. Looked online and can not find much info and manual is of no help.
  • 3 more comments
  • alvinbraumbe Oct 27, 2008
    same
  • dputdog Nov 29, 2008
    Same TV same problems, after unpluging and repluging multiple times can eventually get lamp to stay on. Thought it was the bulb but now being told are capacitors?
  • qualitytom Apr 04, 2009
    I have similar problem. When I turn on the tv, after about 5 seconds, the on/off switch flashes red nine times--forever, I unplug it and try again. It may start, but I have two blinking images for about five minutes then all is well. This is only true with HDMI and Componect from the cable box. TV directly is ok. Even a second cable box soes the same, even watching a recorded show.
    When I turn on the TV, after about five sevonds. the on/off button blinks red nine times--forever. I unplug it and try again and it usually works, but then I get a double image on the screen that blinks for about five minutes and then clears up and all is fine. This only affects HDMI and Component input from my cable box. TV signal is ok. I have tried an new cable box--same results.
  • Anonymous Mar 27, 2014
    Won't turn on and red light flashes in a sequence of 4 what can the problem be? Turned power off for some time and then reconnected but still not working. Help
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
I have a Panasonic 42" plasma, only 18 months old...was working fine with no problems until about 10 days ago. TV would not power on, instead I would see 7 red flashing lights on the power button followed by a pause and then repeat 7 flashing lights. I called Panasonic, I knew I might be in trouble because I did not purchase an extended warranty and my one year warranty was expired. I think the Key to getting cooperation with customer service is to be extremely nice to whoever you talk to on the phone. The first person I talked to tried to get me set up with local tv repair-service people. I asked her to check to see if Panasonic knows about this problem and if I could speak to someone who might be able to help me get this repaired without spending my money even though the warranty was up. She told me to fax her the model number, serial number, my name, address and a brief description of the problem, which i did. Two hours later, they called me back and set me up with a technician to come to my home and fix the problem....at no charge! Two days later, my tv was fixed and it didnt cost me a penny! Apparently, Panasonic knows about this problem and they are fixing it on a case by case basis. If you are having this or a similar problem, call them and be extremely nice on the phone. Hopefully you will get the same good results as I did.
Posted on Apr 21, 2009
I had the same problem power button lights up red and then blinks i email panasonic lucky me they
told i have to replace both fans and maybe the lamp because the fans cool down the lamp on tv so i did it coast $120 it turn on i had no problems no more
Posted on Jan 03, 2009
Check out this manual. https://panasonic.ca/PCS/OperatingInstructions/PT43-50-60LC14K-OI-Eng-Fr.pdf Warning lights is defined would be same for dlp.
Posted on Oct 22, 2011
Absolutely, I took the back off and blew out all the dust, compressed air and a shop vac to catch the flying dust. I took both fans out and cleaned themmanually and put it back together and bingo, it has been running perfectly for more than 24 hours since.....
Posted on Jun 02, 2010
I have a Philips flat screen TV, Model 50PF9630A/37 i replaced some blown cap on the power supply board now the red light flashes in a sequence of 7 flashes, any assistance would be appreciated.Guy
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
Jan 10, 2017 | Philips Televison & Video
My tv cuts on but flashes red light 5 times and shuts off
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 10, 2017 | Televison & Video
I have a 60 inch sony tv that have a red flashing on the lower left side,no picture when I turn it on and there is ringing sound.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 09, 2017 | Sony Televison & Video
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Jan 08, 2017 | LG Televison & Video
How to reset lamp timer on panasonic pt-50dl54j
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Panasonic Televison & Video
Tv will not turn on, orange light flashing
Could be an open internal fuse or power supply failure
Jan 07, 2017 | Televison & Video
I have a HL67A750 Samsung no picture no sound blue light luminated on front 3 LEDs flashing
Jan 05, 2017 | Samsung Televison & Video
No Video Or Sound - Stand By Light Flashes 5 Times
If the tv was made before December 2008, there is a capacitor settlement from a class action lawsuit by Samsung. Supposedly (at no charge) they will send a repairman to replace the capacitors.
Nov 27, 2013 | Televison & Video
Samsung DLP HLS4266W
Check the fittings of the color wheel. Refer this site for more details.
May 17, 2013 | Televison & Video
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
5,958 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
