Question about Fuji FinePix A345 Digital Camera
Lens does not project
I have a fuji finepix a 345. when I turn it on, the lens stays in the housing and does not project out. I have changed the batteries, turned the camera on and off, and the camera does turn on and has a display on the screen in back of the camera. Also, there is a beep when the camera turns itself off after no use. Thanks in advance.
  • Anonymous Oct 22, 2008
    zoom opens only once in awhile.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
  • 12 Answers
SOURCE: fuji finepix a510
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Posted on Jul 07, 2008
  • 244 Answers
SOURCE: Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Posted on Apr 08, 2009
Mykel_N
  • 315 Answers
SOURCE: Fuji Finepix S1000fd Lens Cover - where can I
I have this company in the uk:
https://secure.fujifilm.co.uk/shop/consumer/digital/digital-accessories/spares/product-123724
you could also have a look on ebay, just type in s1000fd lens cover and see what you come up with.
Cheers
Mike
Posted on Jul 06, 2009
SOURCE: I am looking for a lens cap that will fit a Fuji Finepix S2000HD digital camera
I've just bought this camera off ebay and after purchasing noticed that it was going to come without a lens cap. After a bit of searching i found this link - it's not an official fugi one but it says it's for this camera.
http://www.cellularfactory.com/camera/FUJI_FILM/4/34801/186034/
I can't find one in the UK though
Posted on Sep 02, 2009
  • 11967 Answers
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 17, 2009
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
Error message on the fuji finepix s1730 says 'turn off the camera and turn on again' - what does it mean, it keeps doing this
I have several cameras and had left my 1730 in an old house for a year. It had been in a bag with the lens cap on and no batteries, but the house left without heating over winter. When I put fully chaged batteries in it, I got a little motor noise but no lens movement. I thought this was the end of it but did #6 above, switching it on while banging the right (grip) side of the camera against my palm. After many times I saw that the lens was starting to move out and after about 10 more times it came out and started to operate. It then failed when I went to macro but it got better as I used it. Now it seems to be back to normal.
Oct 31, 2010 | Fuji FinePix S7000 Digital Camera
Lens will not close when camera is turned off
May be there is some spec of dust stuck in the lens well. You must use your vacuum cleaner to pull out the dust from around the lens housing while powering the camera on and off.
Oct 29, 2009 | Fuji FinePix S1000FD Digital Camera
Lens for a finepix s5600
I need to know if my wide angle lens will fit other camera brands
Nov 18, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji FinePix F700 LCD & Zoon Lens
Is the battery fully charged? Or is the battery near the end of its useful life? Some batteries hold a charge better than others-- I have 2, both used well, and one seems to last longer than the other...
Aug 25, 2008 | Fuji FinePix F700 Digital Camera
Fuji FinePix E510
Hello
When I switch my camera on I get the message on the screen "Zoom Error" the lens do not extend as normal but stay shut. Can you help please
Aug 07, 2008 | Fuji FinePix E510 Digital Camera
Fuji FinePix F470 Digital
Try another battery, it's possible current battery no longer viable or needs a deep discharge recharging.
Dec 27, 2007 | Fuji FinePix F470 Digital Camera
Zoom error message
The higher end fuji's are good cameras. The A345 and A350 are a piece of crap. Low end Walmart cameras.
Oct 29, 2007 | Fuji FinePix A345 Digital Camera
F650
'fraid not, I believe it does that to save battery.
Mar 01, 2007 | Fuji FinePix F650 Digital Camera
Fuji FinePix A345 Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
