Problem with GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Cant switch to water
Will not change to water when button is pressed changes between crushed ice and ice cubes fine and lights up and emits a beep but not with the water
Posted by avatar on Jan 21, 2012
Solutions (1)
Best Solution
You would have to disassemble the dispenser cover from the unit and inspect the switch that controls the water function and assure that when you press the button in it is activating the switch. You can also remove the switch from the unit and using a multimeter perform an ohms test on the switch to assure that the switch is good as well. If the switch is working fine then you would pull the unit out and check the water valve in the unit and assure that the solenoid on top of the valve is actuating when the switch is depressed in the front if the switch tested good and you cannot get the solenoid to work then replace the water valve. If you have any further questions message me back.
I await your reply
Thank you,
RIck
Suggested Solution (3)
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
  • by Author image Carl Schulzetenberg Over a year ago
Source: PSS26PSTA SS - Only dispenses crushed ice.
Was this solution helpful?
No
Yes
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
  • by Author image DAVID LOGAN Over a year ago
Source: Ice dispenser only dispenses crushed ice
No
Yes
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
  • by Author image Franklin Ouchida Over a year ago
    • By avatarFranklin Ouchida Aug 26, 2007
    • check the wires at th bottom of the door they may be cracked or broken..there may be a zip tie that cause the wire to brake if the wire is broken you will need a new door. as it is all one unit.. let me know if you find something..
    • By avatarFranklin Ouchida Aug 29, 2007
    • there is also a solenoid in the flapper that could be stuck or frozen... let me know
Source: ice maker
No
Yes
Add Your Solution
See all GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator Problems
