Question about Canon PowerShot SD600 Digital Camera
LCD screen is black
When the camera is on the LCD screen is black with some light movement when pointed to light. Video & photo taking works except everything is black. The menu works also. Our son had the camera and we don't know what he did to it, maybe dropped it? Is this a problem with the lens? Is it fixable?
  • 489 Answers
Hi
If you look really closely at the screen can you see an image? You say you can see if you point the camera at bright light... Sounds like your backlight is either damaged or just unplugged.
If you are comfortable doing the repair, you need to open up the camera and remove the front and back case. Check the small ribbon cable under the LCD, is it damaged or unplugged? Try taking it out and plugging it back in, now does it work?
Keep the camera away from static shock, and only turn the camera on with the front and rear body on, never off.
If you need somebody to do the repair for you, we are an affordable digital camera repair business (Google: darntoothysam) and we can definitely take care of it for you.
Good luck from Darntoothysam com
Thomas
Posted on Oct 16, 2008
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
Hi. The LCD screen is black and won't take a photo...
This is a common problem... it is time to change the camera
Jan 19, 2010 | Sony Cyber-Shot DSC-P200 Digital Camera
Camera works but the screen went black A640 except for video and color swap. Did I press a button? I was shooting in cold weather.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
But if you've already tried this, have you also tried downloading any of your photos taken with the black screen to your computer? Are the photos also black? If so, you might instead be experieincing a stuck shutter (possibly due to the cold weather).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jan 03, 2010 | Canon PowerShot A640 Digital Camera
When taking photos with the camera set at the shutter priority, all the photos come out black. I have a lens with a f/2.8, but the on the screen on top the camera, the f reading is showing LO. I have...
You mention everything except the shutter speed. When the aperture shows "Lo" it's saying that there isn't enough light at your selected shutters peed to produce a good exposure. That's why you have dark photos. You may need to bump the ISO up higher, or use exposure compensation to make it work well. For a football game, 1/750 is nice, but you can usually make 1/500 work.
Sep 27, 2009 | Nikon D300 Body Only Digital Camera
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Ricoh GR Digital camera
Jun 10, 2008 | Ricoh GR Digital Camera
Coolpix nikon digital camera
This sounds like a broken or cracked LCD screen. The backlite is working, thus you will get the white screen. The LCD could also be disconnected internally, or has other problems. But this is a direct problem with the LCD.
A camera like this can usually take pictures, and you may be able to use it to set the menus by using the video cable to the TV or computer screen (some flat screens have video inputs).
Dec 04, 2007 | Nikon COOLPIX L3 Digital Camera
Taking photos or video works sometimes
Hi, I think this is problem due to LCD Diplay. Sangita
Jul 23, 2007 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
