Question about D-Link RangeBooster N Wireless-N USB 2.0 Adapter
Problems connecting to internet after installing rangebooster 'n' usb adaptor to laptop
I have D link wireless G router (DIR-300) connected to my pc then have a rangebooster n usb adapter (DWA-140) on my laptop. Trying to get a wireless internet access for my laptop. The laptop says it has found the network and is connected but when i try to use internet explore or outlook express it says I have no connection or it trys to dial a connection. Any ideas what I have done wrong setting up?
You might need to uninstall the product first, then install it again.
Remember to key in the correct SSID (network name) and the passphrase(or password) of the d link router you want to connect to.
Then choose the wap2 or wap security coz dlink supports them both.
Then it should be ok.
And one more thing! Disable the othere drivers when using the dlink n range booster. They might cause some complications.
To disable: go to control panel>device manager>network adapters,
then right click the other adapters except for the dlink adapters.
It should be ok now.
Posted on Feb 08, 2009
    Genius:
  • 2,120 Answers
Go to www.dlink.com for customer support.
Posted on Oct 16, 2008
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
I have an netgear router, but dont have an cd drive to install the cd. My laptop is old. how would I install this
Connect your laptop directly to the internet (plug the Ethernet cable into your network interface) and download the drivers from the d-link website.
If you have USB ports, you can use another PC to copy the CD to a Flash drive.
Jan 21, 2010 | D-Link / RangeBooster N 650 / DIR-635 /...
Hi. I just configured a DLink DIR-300 wireless router on my laptop. During the installation, it required me to keep the ethernet cable connected between the router & the laptop. I finished the...
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Aug 19, 2009 | D-Link DIR-300 Wireless Router
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Not able to configure wifi router
im having trouble with wireless connection it says i have full signal but is not connected
Feb 13, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
VPN problem with Dlink DIR-300
Update your firmware to the latest. I had the same issue and the issue is gone after the upgrade.
Dec 31, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
Dlink dir 300 internet problem
First you have to make sure that you connected it correctly. the cable coming out of the modem should be connected to the single port (Internet port) at the right when facing the back of the router.
All computers that are wired through it should be able to access the internet. if one of your computers cannot access the internet you may want to check the IP address that you are getting. (go to a command prompt and type ipconfig).
If you are connecting a wireless computer check the wireless security setting which you can find at the configuration (setup) page of the router. to access the configuration page check the owner's manual.
Oct 08, 2008 | D-Link / RangeBooster N 650 / DIR-635 /...
D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-link DIR-635 router
Hi, I am assuming that you can connect to your router's web based interface (192.168.0.1). On a PC LAN wired to the router, open a browser; Type "192.168.0.1"; Log-in username/admin and password/(blank); Go to Tools > Misc and the option to select the WAN speed (bottom); Lock the speed down on the WAN port of your router to 10Mbps (Some versions do not have this feature). Hope this works for you. If not pls post back with your modem brand/model. You may also want to log the IP settings (IP Add, Subnet Mask, Default Gateway, DNS Servers) of the PC that is directly connected to the modem when you can access the Internet when not using the router. Good luck and kind regards.
Oct 02, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
D-Link RangeBooster N Wireless-N USB 2.0 Adapter Logo
289 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
