Question about Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Only has a line through center of screen
Started just occasionaly now is permanent. Just a white line through center of screen. The dvd player will not read dvd properly, plays for a while and then goes into skipping and no play at all.
help
  • Anonymous Nov 28, 2008
    tv shos only a white line
  • Anonymous Dec 13, 2008
    it just has a white line right through the center horizantally
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Problem started as a simple cold solder joint. Now the connection has either burnt to the point of not making any connection at all, or the vertical output has gone out due to the stress. As far as the dvd player goes. Sounds like the microprocessor is heating up and going bad. Nothing can be done other than replacing the whole unit.Should be able to order it from Toshiba.
Posted on Feb 11, 2010
Describe how to fix vertical lines on the I-PD720 Insignia portable dvd player?
if these lines are permanent the lcd screen is faulty. u need to get the lcd panel replaced.
Aug 19, 2011 | Insignia I-PD720 Portable DVD Player
I have a white line running down the centre of my tv screen. It is a jvc and dvd combo. the dvd player is on the side of the screen
If you are having a white line in the middle of the screen and sound it an indication that you have blown the vertical deflection amplifier. Don not switch on the TV till you get it fixed as you can damage the picture tube in the central area permanently.
It is a 11 lead IC mounted on an a aluminum heat sink. Will cost you about less than 10$ plus labor to replace.
Jul 15, 2011 | JVC AV-32020 32" TV
Center of screen has horizontal flashing white lines all through it. Just in the center of the entire screen
check if
* might the flex connector/cable is dis-align or got loose contact.
* LCD components (some parts) are curroded and need to be clean
if you do it on your own,take a little care of opening it.
On Top (LCD screen housing) : just use a guitar peak in between the housing
On Bottom (Circuit boat) : unscrew all side and corner of it..(beware of hidden wires and flex connectors.
* using hot air or a hair blower... target the LCD components attach at the back of the screen,maintain the temp cause my burn the screen and assemble it properly and fit each socket.
if you got the same problem... might need a replacement and bring it to a authorized service center...
good luck.
Jun 06, 2011 | Durabrand DUR-1700 Portable DVD Player
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
I have a proline dvdp920w ,the fault is the screen goes white the sound still plays
Screen goes white maybe moisture and condensation problem. But may have something to do with contact resistance on the 220 volt supply for LCD tin oxide. Contact resistance need an impact to shift the contacts to restore low resistance contact. Have experience to restore white screen by gently pat the sides of the device.even though Its a cheap fix; but use a fan to lower moisture in your room will fix it permanently.
Nov 21, 2010 | Panasonic DVD-LS55 Portable DVD Player...
On my tv screen I have a vertical white line with some colours
the x or y driver board is failing.best to have a servicer checked out
Jul 10, 2009 | LG M4201C-BA 42 in. HD-Ready LCD
Thin white line on screen
this is a screen fault... this should be sent to the maufacturer for repair/replacement if still in warranty
Sep 28, 2008 | Durabrand DVD-1002 DVD Player
Sony DVD player color problem
All These units need servicing, They all are having problems with the video output circuit. It could be a coupling capacitor or the video chip itself heating up and distorting the output after short playing periods.This may be a simple fix of changing the output coupling capacitors. But it also may be some internal distortion in the chip. These unit need to be tested on a oscilloscope and check out in the video out input section to look for possible component failures.You should contact a service center that will test your unit and give you an evaluation of the cost effectiveness of a repair. Hope this helps you with your problems.
Oct 29, 2007 | Polaroid 7" Two-Screen Portable DVD Player
Toshiba MW27FP1 27 in. TV/VCR/DVD Combo Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
