Question about Whirlpool Dryers
No heat dryer was taking a long time to dry so my fiance' took off the power cord to hook up to another dryer (used) and it sparked. He then hooked it up to original dryer and the drum will move and there is air but now it won't heat up at all. I did remove all the lint inside that was built up. Could it be possible that the power cord shorted out? I have already checked breakers and they are ok. I was told that it is probably the thermostat. HELP!
  • chramian Oct 16, 2008
    ok what do I use to determine that, some special gauge? What is it called, where can I get one and how do I use it?
  • 283 Answers
You need to verify that you have 230 volts to the dryer's terminal block, 115 on each "leg" and a proper neutral. Once that's done we can go on diagnosing the problem
Posted on Oct 16, 2008
Would the power cord installation have anything to do with whether the dryer has heat?
it has no heat because the heater is not working and was the reason it was sold
it may be a faulty heater element or switch but the cord has nothing to do with it.
May 20, 2015 | Dryers
I have a imperial whirlpool dryer. I thought it was electric, it has gas hook up and a electric plug as well , can it be bothZ?
Yes, it will be both. A straight electrical dryer is hooked up to 220 volts of electricity and uses that voltage to run both the motor and the heater. In a gas dryer, you only need 120 volts to run the motor and run the igniter for the gas, which provides the heat to dry your clothes. Hope this helps!
Feb 24, 2015 | Whirlpool Dryers
I have a 1989 cobra 29 Ltd classic cb. It got water spilt on it sitting on my tabble so I took the covers off and took a heat gun to it and dried it. I also disconnected the internal speaker and left it...
# 1 you should never dry out a radio with a heat gun.#2 the reverse polarity diode is what is blowing out. take that wire you fixed and toss it.go to Rad Shak or a truck stop and buy a power cord with a lighter plug attached. .Then have someone you can trust replace d23. hook up your coax then your cord turn it on and you are good to go.
Aug 01, 2013 | Radio Communications
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
We just moved and hooked up our dryer and it wont dry our clothes
1ST CHECK POWER OUTLET IF YOU HAVE ELECTRIC DRYER, IT SHOULD HAVE 220V COMING OUT FROM OUT LET. IF POWER IS OK AND HEATING BUT LONG TIME TO DRY THEN CHECK YOU DRYER VENT.
IF YOYR DRYER VENT AND POWER IS OK, THEN IT COULD BE ONE OF THE HI LIMIT OR YOU HAVE BAD HEATING ELEMENT
Feb 28, 2010 | Kenmore 62602 Electric Dryer
My dryer all the sudden is blowing the fuse at the panel. It runs for a short time and then blows the fuse. Sometimes it just keeps running and doesent blow the fuse. It is hooked up properly and has never...
UNPLUG THE CORD then,.,,,maybe the cord hooked to the dryer terminal block and just follow the cord to the unit and take off the axcess panel to power cord hookup is shorting out and needs to be replaced being hooked up properly is why its the first place to look for its
Aug 26, 2009 | AEG Dryers
MY DRYER TAKES A LONG TIME TO DRY CLOTHES. HAD IT FOR 5 YEARS. MOVEDTO NEW HOUSE AND HAD TO CHANGE POWER CORD BUT IT WORKED FINE AT FIRST. DO I NEED A NEW HEATING ELEMENT?
It sounds like you may have hooked it up to 110volts while most dryers need to run on 220volts. If your new house has gas then a gas dryer would run on 110volts as it gets it's heat from the gas flame. If this is the case you would need to run a new 220volt line to the unit. this can be costley and you may be better off trading your electric one for a gas one as that will probally be cheaper to run in the long run.
Aug 21, 2009 | Dryers
Wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Sounds like you did everything correctly however it is possible the wall receptacle may be miswired. The white wire is the neutral, black and red are the line feeds ( hot ) and green is ground. If you are sure the receptacle is wired correctly and that the power cord is wired as you say it is, then there may be an internal issue with the dryer..or some packing material was not removed and is burning off. ( make sure the drum can spin freely and you aren't smelling a belt burning) The red and black are normally on either side of the neutral but you should match the color code on the terminal block on the dryer. Hope that helps...
Regards,
Rick
Jan 03, 2009 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
