Question about Dell Dimension 4600 PC Desktop
Need additional advice
Windows XP could not start because the following file is missing or corrupt file in this path: WINDOWSSYSTEM32CONFIGSYSTEM
For this what you have to do is insert the Operating System CD and boot with it and goto repair windows.
hope this will helps you
Byee...
Got this solution from a previous post but I have a question - how do I get into the repair window. I have a dell dimension 4400 and I have put the OS in the cd drive, the choices I have are del to resume and F12 to see boot menu. I cannot find where to go to do the repair. Any help?
    Problem Solver:
  • 6 Answers
Press f12 then choose boot to cd rom drive then press enter after that when youy get the message press any key to boot to cd keep pressing the spacebar you should get a message that says windows is loading files and when you get to the page that says install windows or repair choose the repair option
Posted on Oct 19, 2008
I have a problem with my netbook which can't start, I have this message: ...the following file is missing or corrupt: windowssystem32configsystem
Hi
Windows system 32 config file is part of the operating system and when this is missing or corrupted, you cannot boot up your computer. The only solution is to reinstall or repair your operating system. Good Luck.
Jan 13, 2011 | Acer Aspire One Netbook 8.9" Notebook
My computer wont boot windows but say's: windows could not start because the following file is missing or corrupt ;windowssystem32configsystem. What can I do?
Boot to you XP CD< press R for recovery console, run CHKDSK /R see if that resolves.
If not, hold Fn While powering on the system and run diagnostics the Hard Drive might be failing
Jul 27, 2010 | Dell Inspiron 1501 Notebook
Windows could not start because the following file is missing or corrupt: windowssystem32configsystem
only one solution: reinstall windows using the Dell Recovery CDs that came with the computer.
Jan 18, 2010 | Dell Inspiron 2200 Notebook
When I turn my Toshiba Satellite A50 on and Windows tries to boot I get the following: Windows could not start because the following file is missing or corrupt: WindowsSystem32ConfigSystem It then says:...
You need the Toshiba CD that says "Operating System"...
If the CD doesn't boot, then boot to the BIOS setup screen and change the boot order.
CD should be listed first.
Re-boot.
Sep 25, 2009 | Toshiba Satellite A50 Keyboard
I get a message that Windows could not start because the following file is missing or corrupt: /WINDOWSSYSTEM32CONFIGSYSTEM I bought this thinkpad preloaded with Windows XP and do not have an original set...
About the only thing you can do is buy or borrow another Windows XP install disc as this is the only way you'll be able to extract the missing file using the repair console. Hope this helps.
Sep 19, 2009 | Computers & Internet
Computer does not boot
you have to installed a new Windows xp but when he ask the repair and new installation the go for the repair you got the old files as it is
Apr 15, 2009 | Sony VAIO (PCWA-A200)
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
Windows xp corrupted
This is supposed to be caused by some missing registry entries in your windows installation. Not exactly sure why this is happening. May be you have some important files that cannot be copied due to a damaged CD. Microsoft replaces the media for you so that you can try installing using the replacement. Click here for more details
http://support.microsoft.com/default.aspx?scid=kb;en-us;326246
You can also try to recover the PC using recovery console. To do it follow the steps below
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:windowssystem32configsystem c:windows mpsystem.bak
    copy c:windowssystem32configsoftware c:windows mpsoftware.bak
    copy c:windowssystem32configsam c:windows mpsam.bak
    copy c:windowssystem32configsecurity c:windows mpsecurity.bak
    copy c:windowssystem32configdefault c:windows mpdefault.bak
    delete c:windowssystem32configsystem
    delete c:windowssystem32configsoftware
    delete c:windowssystem32configsam
    delete c:windowssystem32configsecurity
    delete c:windowssystem32configdefault
    copy c:windows epairsystem c:windowssystem32configsystem
    copy c:windows epairsoftware c:windowssystem32configsoftware
    copy c:windows epairsam c:windowssystem32configsam
    copy c:windows epairsecurity c:windowssystem32configsecurity
    copy c:windows epairdefault c:windowssystem32configdefault
  6. Type exit to quit Recovery Console. Your computer will restart.
Source:http://support.microsoft.com/kb/307545
Dec 29, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
Dell dem 3000 will not turn on
Reinstall the missing or corrupted file
May 25, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 4600 PC Desktop Logo
67 people viewed this question
Alun Cox
