I am looking for a store to assist with a problem that needs repair to my lap top,the connection that enables me to plug in my lap top has come out somewhere and needs to be replaced as I can not plug in for connection.
  • 4,338 Answers
Is this the power connection? If it is you should be able to find a Tech that could repair it for you inyour area. Enter your Zip code on the FixYa page where it is titled "Repair Service" there you could browse the repair directory and hopefully find someone near you.
Posted on Oct 16, 2008
Want to connect my JVC AV-36D502 to my lap top computer
hi hmwpeg
• you may need a PC to TV Converter
like one of these:
instruction is on the web page.
• to enable on your laptop, set your JVC TV as secondary monitor.
• use the Catalyst control panel.
hope these helps
thanks for choosing Fixya for assistance
Sep 05, 2012 | JVC AV-36D502 36" TV
Help repairing Fast Ethernet Adapter
could well be a faulty RJ 45 or the socket in the lap top is lose and causing dry solder joint, had this in the past where all looks working but socket needed re soldering... You should not attempt this yourself as it requires special equipment to re solder these. also worth trying a different cable. hope this is useful.Steve.
Mar 24, 2012 | HP Compaq Presario 2100 Laptop
When plugged in the unit starts to smell hot like an electical burn,
Turn it on turn it over and see if the fan is operating. If not power your lap top off and replace the fan. You may have to not use this computer until the fan is replaced it is advisable not to. The smell you have may be dust smell when it gets hot. Clean throughly and make sure that all the dust is out of your computer. Also recommended a lap fan also which goes underneath the laptop to assist with cooling.
Lap tops are very touchy and need to be kept cool at all times otherwise you will be purchasing a new lap top if you do not take care of the cleaning or the cooling or the fan not working or spinning slowly. Check all this out. Critical if you do not understand what I mean take your computer to a local shop for immediate care. I hope this assisted you. John
Feb 01, 2011 | Toshiba Satellite P205D-S7802 Notebook
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example:
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Itunes will not connect to the itunes store
I don't know your iTunes version, if it is the latest version, I think it will work smoothly. And the current version of iTunes is 9.0.2, you can get it here:
Good luck
Nov 19, 2009 | Apple iTunes
I assume you mean, Lap Top, because they sit on top of your lap. :).
Make sure your laptop's nic is enabled in BIOS, and that you have the driver installed, and that Windows has it enabled, and in DHCP mode. (call your ISP for settings). Also, make sure your pc security is allowing connection thru that port, and that your router or modem is working properly.
Nov 06, 2009 | Computers & Internet
My Linksys wrt54gc quit working. I get amber
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Nov 06, 2009 | Linksys WRT54GC Compact Wireless-G...
Lap top not charging . purple light is not on. is it battery or charger?
the charger lasts longer than the battery .you need another lap top battery
Oct 16, 2009 | Computers & Internet
How can I connect my metropcs samsung sch r450 as a modem to my HP omnibook 6000 lap top? Thank you, Phil.
First of all you need to contact Metro PCS to see if they support it. Or if you need to pay extra for it (normally you do, it is called tethering)
If they support it and it is enabled you will need to look get teh software from Samsung's website and ofcourse a data cable, unless it supports an IR or Bluetooth connection.
Aug 24, 2009 | Samsung Computers & Internet
Cant connect to the internet on my lap top
first thing is to identify the wireless settings of the router,you need to identify the wireless name (SSID), channel and the encryption you are getting from the airlink router. Next is to make sure that the wireless computer has enabled wireless signal/ or the wireless is on.
after that, you may connecting wirelessly to the computer, right click wireless connection and go to view available wireless networks, try to connect -input the encryption key from you wireless router or password and hit connect.
Jun 28, 2009 | Airlink AR430W Wireless Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
