Question about AT&T 8925 Tilt Smartphone
How to change the time
Somehow while i was riding my motorcycle a week ago i hit something and changed the time on the frontpage(upper righthand corner) to a clock&t (analog) ive called at&t and well.... now im contacting you. any help would be greatly appreciated!
  • redsoxsean71 Oct 16, 2008
    THANKS MIKE!!! THAT WORKED!! YOU GUYS ROCK!! AND AT&T COULDNT FIGURE THAT OUT!!
    Problem Solver:
  • 15 Answers
If you tap and hold on the clock, an option to change it back to digital will appear.
Mike
Posted on Oct 16, 2008
I want my original yahoo mail screen saver with the white background
In the upper righthand corner of your yahoo mail, there should be a little gear icon. Click on it, then go down to settings. Under the "view your mail" tab or whatever it says there, go down to the bottom where it says "basic". Check the little box and hit save. That will revert the layout to what's called the "classic" view.
Nov 30, 2013 | Computers & Internet
Jerky when getting on and off the throttle and changing gears
Sounds like drive train slop, is there a chain final drive, maybe too slack. If not that, then maybe something they "adjusted" during tune up. Also the throttle may have too much slack in the cable.
May 14, 2010 | 2002 Suzuki SV 650 S
Somehow the clock is displaying 24 hour time format. I want to get back to 12 hour format. How?
Push the mode button twice to enter the "set time" mode. Once the digital display is blinking, keep pushing "mode" until the PM display section in the upper left corner comes on. Once that happens you are back to the 12 hour clock. To set the clock, use the 1-4 buttons to set the hours and minutes.
Hope this helps.
May 11, 2010 | Sharper Image SI686 Clock Radio
Blades wont activate
Check the timing belt, the belt just above the blade. The blades, if not turned 90 degrees to each other, will clash. Dumb design?; perhaps, but you need some way to overlap when you turn so tightly. I have an early 2000's vintage, but remove the shroud and check the belt. It may be broken. You can actually raise the deck to it's maximum, remove the spark plug for safety sake, and if each blade spins independently of each other and real easy [though one could be jammed somehow], you probably broke the belt. They were just a few bucks shy of $100 a few years ago; I bought two when my last one broke, and luckily I haven't needed the spare. When/if this is the problem, syncronize the blades so that one is 90 degrees to the other. The factory has marks stamped on the pulleys and housing somehow (I'm trying to remember exactly), but in the end lining up those marks achieves that orientation. Hope this helps, Chuck in Cleve Ohio area
Jun 15, 2009 | Ariens 34 In. Zoom Series Riding Mower
How to display time
Click on Main Menu, then Settings, then Personalize, then Home Screen, Hit down arrow to Clock: then hit Change Select Digital then hit Select Again, the Screen will then confirm Clock Changed. Now go Back to your home Screen and you should see the clock display in the upper right corner just under the Battery Icon...
May 02, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Mar 29, 2009 | Elgin 0518709FA
Toshiba satellite touchpad
READ THIS POST NOT THE OTHERS. you can configure each of the four corners of the TouchPad surface to act as different buttons when tapped. These corner regions are called Tap Zones. to disable this feature goto control panel, mouse, device settings, settings, tapping, tap zones, disable tap zones.
Feb 17, 2008 | Toshiba Satellite A135 Notebook
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Open Questions:
AT&T 8925 Tilt Smartphone Logo
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
