Question about Canon PIXMA iP8500 InkJet Photo Printer
Canon pixma ip 8500 won't feed paper
Printer won't feed paper from either cartridge. printer begin printing, sounds as if it is printing but printed page never appears, when printing from the lower cassette - gets hung-up passing the back transport door. paper from upper cassette feeds unevenly and jams.
  • 1 more comment
  • alinabreuil Nov 01, 2008
    paper on top feeder goes sideways and jams
  • jmonty Nov 02, 2008
    I have exactly the same problem.
    Was initially intermittent, but printer is now unusable.
    Any assistance would be appreciated.
  • Anonymous Mar 22, 2014
    There is paper in the printer but it says there is no paper in upper cassette
I have discovered that my problem was a one inch nail which had at some time been dropped into the paper feed slot. It could not be seen from the outside of the printer and was only discovered when I removed the side trim and top cover. When closely inspecting the nylon roller system that feeds the paper out, I saw a tiny piece of metal that looked out of place. Further probing then loosened the nail back to the paper input area.
My printer is now back in full operating condition after spending a couple of careful hours finding out how to remove the trim.
A well worth while exercise in my case.
Posted on Nov 03, 2008
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer will not feed paper, when it tries to
the rubber rollers that feed the paper might be dusty so the paper slips
May 17, 2009 | Canon Pixma MP500 All-In-One InkJet...
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Pixma ip 3000
I think that if you use the bottom tray to load the paper, you can use the different sizes of paper to print. Make sure to click the second button inside the lid that shows the direction the paper is fed into the printer. hope this helps!
Jan 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma IP 8500
Sounds like the print head is bad or seriously clogged. If you have done repeated print head cleanings with no success, I believe Canon sells the print head if your unit is out of warranty.
Manuals available for download here.
May 19, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon Pixma ip 2200
send me printer driver canon ip 2200
Nov 12, 2007 | Canon PIXMA iP2200 InkJet Photo Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
197 people viewed this question
old marine
old marine
