Question about Kenmore 30169 Electric Single Oven
Nothing works but the clock and shows F7
Shows F7
I had this on my stove for months and it also didn't work. Finally, Sears changed the computer board and no trouble since then -- five years ago@
Sharon in Covington, La
Posted on Oct 30, 2008
Alarm comes on and display shows f7 code
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore wall oven digital screen is blinking F7? it has a digital button screen. i can clear it but it comes on again a minute later. no other buttons work?
Here is the list of f7 codes for this oven and what they mean and what needs to be checked and fixed
F7 Function key shorted Replace touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Oct 19, 2010 | Kenmore Ovens
I have a Kenmore built in oven, it doesn't work. There is a code F7. What could that mean?
Hello there:
Oct 05, 2010 | Kenmore Ovens
Kenmore electric built-in oven model 911.47702201 just started showing 2 error codes and beeping. F7 is in red and on the left side of the display, E8 is in green and flashing and is on the right side of...
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. Good luck!!!
Nov 04, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
I am getting a F7 on the display and nothing will work other than the clock.
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 31, 2009 | GE Ovens
I oven is showing -F7- what is that
You have a function key stuck or shorted. Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Regards, --W/D-- Please feel free to rate this solution! Thanx!
Jul 31, 2009 | Magic Chef Ovens
F7 shows on display and display getting dimmer over months
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
Jul 16, 2009 | Thermador SC302T Electric Double Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 30169 Electric Single Oven Logo
139 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
