Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Adding Softner Pouring in the softner does not work anymore it releases the softner after the rinse. I think during the spin
  • 324 Answers
Try taking the dispenser off and cleaning it might have a build up of old softner
Posted on Nov 05, 2008
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Water is coming up in fabric softner cup during rinse time front loader
this is normal
water should go thru the softner and into the drum when the machine rinses to introduce the softner to the drum
Dec 05, 2014 | Kenmore Elite 45986 Front Load Washer
Htwp1200doww where does fabric softner go
You have to do it manually. Ugh. See below from manual:
Liquid Fabric Softener (Manually add during rinse cycle)
2. Measure liquid fabric softener carefully, following instructions on the bottle, and add during the rinse cycle.
OPTIONS (on some models)
Set this option when planning to manually add fabric softener during the rinse cycle or when you use extra detergent or bleach to clean hazily soiled items. It provides an enhanced rinse.
Oct 04, 2012 | Hotpoint Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Fabric softner does not empty into washer during rinse cycle
Hi not sure how these work as we dont have them in the UK. With UK machines the soap and fabric softner are put into a drawer that pulls out the front of the machine. When softner and soap arnt going into machine properly we take drawer out and wash it in warm water, you usually find a lot of gunk built up blocking it, perhaps you have a similar problem. Hope this helps
Jul 27, 2011 | Kenmore 43052 Front Load Washer
When to add softner during wash
Hello, the softener is added during rinse circle but bleach needs to be added at the beginning. First add the detergent, then let the water get it nice and sudsy, then add the bleach then the cloths. It is when you get to the rinse circle that you add the softener.
May 22, 2010 | Whirlpool Inglis IP4400 Washer
Softner stopped draining out of the compartment during the rinse cycle. When I open the compartment after cycle stops, there is still softner in the cmopartment
try pouring really warm water in the compartment or using small soft toothbrush type brush to clean out the build up of softener. You might try thinning your softener in the future with water if it is very thick. this works for me
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Hi, If there isn't a softener container in the top of the agitator, you can get a softener ball from your local grocery store. Just put the softener in before you wash and it will open to release the softener during the spin cycle. It works great. I use it all the time.
I hope this helps. Please let me know if I can assist you further
May 20, 2009 | Washing Machines
I have Kenmore 3.5 super Capacity, PART # 48102. It no longer goes full cycle, stopping during or just before the rinse cycle. It also no longer dispenses bleach or softner.
I dont know about it not going through the full cycle, but as for the bleach and softner dispenser problems, i had the same issue. About 7 months after i had this same machine,,, the softner would enter the cycle during the first rinse, which i supose isnt a major problem, but it was quite annoying because by the time the 4th rinse was over,,, there was obviously no softner left on the clothes. It was still under warrenty so i had sears come over. They replaced the control board, thinking it was a timing problem, but it didnt solve the problem. They scheduled me for another time, and again sent over a repairman who didnt know what he was doing. I being 20, like to take things apart and see why they broke or how they work, so i pretty much knew what the problem was. I told this second guy what i thought and he ordered the part, 2 weeks later came back after i had recieved the part, installed it, and PROBLEM SOLVED. So im thinkingthis could be the same problem your having. If you take out the detergent draw to clean it or for whatever reason, if u look inside, and up,,, you can see holes where the water drops from,,, and that is the part you probably need fixed. I really cant remember what the part is called,,, but im assuming its something like Detergent Dispenser Asembly or somethng like that.
May 25, 2008 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
