Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby Vacuum Hi Bruce, In my opinion, yes the Kirby would be worth it, as long as you are not replacing the motor. The switch would be the most expensive part besides the motor that would need to be replaced. The switch costs USD 49.99, the cord is roughly $39.99, and the carbon brushes are $29.99. I can easily walk you through any of these repairs should you need help. Kirby's are great vacuum cleaners, that usually last 30+ years. Brand new these machines sell in the US for $1600 or more, and I hear they are even more expensive over seas. We are just starting out on Fixya, and I would like to ask you to vote Fixya on your question so that we may get a good reputation on this site. We REALLY appreciate it. Let me know if you have any other questions that I can answer for you. Thanks, Chris Jones GoVacuum.com
  • 1 more comment
  • sonnyg268 Feb 09, 2009
    the plug in side of vacuum is cracked and i can't put plug in how do you change switch
    the power switch is cracked so it don't work when i plug the cord in how do i remove power swithch
    what happened to free is this fauls advertizment
    Problem Solver:
  • 5 Answers
You can get better prices from Goodvac.com
Posted on Aug 23, 2010
Kirby Vacuum Cleaner on/off switch won't stay switched on
If the motor turns on turns off in the course of the vacuuming, check the cord or the switch This is how you replace your cord on a Sentria vaxuum.
Jan 15, 2013 | Kirby Vacuum Cleaner Switch For G3-Sentria...
We have a 2001 Kirby G vacuum. The cleaning lady was using it in one room, then brought it to another room and plugged it into another receptacle. It wouldn't start. Naturally we tried other outlets on...
Such an abrupt fault is more than likely a very simple fault, such as a loose wire or damaged electrical cord or a faulty switch. I would most certainly check or have these components checked before purchasing a new machine. They should be relatively inexpensive and easy to replace.
Best wishes,
Graemevm
Apr 18, 2010 | Vacuums
Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
Dec 28, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Kirby G5 vacuum
check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby vacuum
There are 2 safety switchs, one on the front that the nozzle activates, and one on the side that the bag asembly activates. The motor brushes and/or armature maybe bad.
Feb 12, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Nov 07, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
123 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
