Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Not making ice
Everything seems hQQked up okay but it doesn't make ice.
  • tmahar1 Oct 16, 2008
    water does dispense from front door, for glass of water
  • 120 Answers
Need more info on brand and model but try this turn water off to refrigerator now disconnect the line from back of refrigerator get a container to catch water now turn water back on if you dont get water call a plumber nothing is wrong with the fridge
Posted on Oct 15, 2008
  • Rosendo Madero
    Rosendo Madero Oct 16, 2008
    check the fill tube that supplies water to ice maker check to see if its frozen inf is not frozen then the repl the water valve the selenoid that supplies water to ice maker might of burned out
How do I diagnos leaking ice maker
If your freezer seems to be working okay, the ice maker has a thermostat closes a switch to start the ice maker harvest cycle. I would suspect this thermostat is bad.
Oct 20, 2014 | Refrigerators
defrost timer is bad.
Dec 23, 2017 | Refrigerators
Ice Maker Doesn't Work
Is there ice in the ice tray? If so the heater is not working to allow the scooper to push the ice out into the tray. If no ice in tray then the fill solenoid is not opening to allow water into the tray. Replace the solenoid.
Sep 19, 2017 | Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
My power window and locks are not working,would this be caused by a blown fuse and which one(the #)
{: ) Check the DDM fuse10amp at the rear fuseblock. If okay, you need to pry and remove the driver door switch, but dont remove the connectors. Using a test light, backprobe on the two thick orange wires for presence of voltage. The testlamp should light, otherwise it is a wiring problem. Also check the black wire if its giving a good ground.
If everything seemed okay, it could be that the driver door switch is not communicating and need to be reprogrammed. If this doesn't work, then your driver switch has a problem.
May 24, 2011 | 2006 Chevrolet Trailblazer
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Elite Refrigerator Trio display panel read ER IF and everything seems to be melting or thawing. Not making ice and water is running from door where the ice seems to be melting? HELP! My freezer...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
41 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
