Water fills up and drain no wash cycle
SOURCE: electrolux Dishwasher 24 " not
if i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
You have to test the heating element with an ohm-meter. It should read very low ohms. If the element seems ok, you have to test the controller to see if it is powering the element (probably should be 120 volts)
SOURCE: Hi i have a Electrolux
This can be a possible fault with the program controller unit. You will need to observe and make some tests as the washer works and stops. So check with all precaution if you are able to use a multimeter.
check the voltage on the motor while agitating. now does it cut off - if so the program controller is faulty , However If the voltage stays but the motor stops then the motor is faulty , the capacitor reduced in value or the mechanical section of the agitator/shaft can be jammed.
Check the program controller, check all connections , remove clean and set. check the door switch.
