Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Lost desktop files and folders
I accidently dropped a (selected all)  large iMovie file from my external drive onto my desktop and all the clips seemed to pan across the screen - - I deleted them but could not find my desktop folders.  Did they bet kicked out of my computr somehow?  no change in my HD folders, apps, etc.
  • JDTec
    JDTec May 11, 2010
    Did you look in the trash? if they are there, drag and drop it to the desktop.
  • 148 Answers
Check in 'trash' if they are there, then simply drag back onto the desktop.
Posted on Dec 11, 2008
How do use Verbatim to back up files
Which operating system ?
Determine how much space you need. The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files. You can do this in a couple of ways. Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties." This shows the approximate of your hard drive, how much space is actually taken, plus the space used by your operating system. If your hard drive is manageable (the space actually taken), back up the whole thing. Your second option is to create a file called "Backup" and copy all of your important files into it. Right-click on the folder once everything is copied over and choose "Properties" to find out the of the folder. This is how much space you will need to back up your important files only. Choose a backup method. Choose either an external hard drive, data disks (CDs, for example) or use an online backup service. Plug the flash drive or the External Hard drive into your computer's rectangular-shaped USB drive. Wait for Windows to recognize the system. Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration. Open the drive on your computer. Open the "My Computer" directory if using Windows XP or the "Computer" directory if using Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it. Transfer files to the flash drive. Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background. Open the folders or locations of the files which you want to save to the flash drive. Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window. Release the mouse button to let the files "drop." Close the windows and directory locations when finished. Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option. Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section. Click the "Save" button to save the file onto the flash drive. Close the windows and files when finished
Apr 03, 2013 | Verbatim Computers & Internet
Can't copy large files onto my external harddrive
What format is the external drive ?
you might need to split the file with rar
I recently downloaded win 8 5gb had it split with rar into 2 files downloaded with IDM trial
The FAT32 format does not support single files larger than 5GB, so if you have a file larger than 5GB you cannot put it on your FAT32 thumb drive. Most thumb drives and other portable media devices use FAT32 format, so this setback makes large files less portable, and that just won't do. Get around this problem by compressing the of the file or by splitting the file up into multiple pieces.
Create a folder for your RAR file and insert a copy of the original file into this folder. RARing a file separates it into multiple pieces, so creating a file specifically for your RAR file will keep the files together allowing you to move one folder to your FAT32 device instead of having to locate and move multiple files. Right click the large file that you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side. Select "RAR" from the "Archive Format" located to the left of the menu. Click the arrow next to "Split by volume, bytes," and select "CD 700: 700mb." This will create a new file for every 700mbs, meaning your your one large file will be separated into many 700mb files that can be put back together as a single file later. Click "OK." Put the folder, containing your newly separated files, onto your FAT32 device after WinRAR has finished separating the file. b> Zip File b> Right click the large file you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side of the file. Click "OK" on the next menu. This menu allows you to customize the compression settings. The only option you need to change is the "RAR" selection to "ZIP" in the "Archive Format." The rest of the default settings will work fine, so there's no need to change anything else. The zipped file will appear in the same folder as the original. Delete the copy of the original large file from the folder and put your newly compressed file on your FAT32 device after the file has completely compressed. The time it takes for the file to finish compressing depends on the of the file. Hope this helps. http://www.all-freeware.com/getfreeware.html?pid=109090&mirror=1
b>
Jan 08, 2013 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Can't find back-up folder
You might have to create a folder you can do this by right clicking in the backup destination drive selecting new folder and name it lets say Back Up 2012 for the excercise.
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
Hope this helps.
Nov 16, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
Does not allow transfer of files or pictures
Plug the external hard drive into your laptop or desktop computer.
Most external hard drives do this through a cable connecting the hard drive to the USB outlet on a computer.
Plug your external hard drive into a wall outlet if it receives power from an AC adapter rather than your computer.
Click on the "My Computer" icon on your desktop, and open the external hard drive.
It will be located under the USB connecting drive, which is labeled with a letter ranging from "E:" to "K:".
Open the folder on your external hard drive where you would like to save the photographs.
usually in my documents my pictures or if you want to save them to a specific spot so as not get them mixed up.
Create a folder if one is not present right click in my documents select new folder and name it lets say my pics 1
Move this window to the bottom right corner of your screen to be used in future steps.
Open the folder on your home computer where the files are being stored that you wish to transfer to the external hard drive.
These may be on the desktop, in "My Documents" or elsewhere in your computer.
If you are unsure where they are located, you can always search for them by file name by going to "Start" then "Search."
Right-click on the photo file, and select "Cut."
Click on the window showing your hard drive files to bring it into use on the screen.
Right-click on the white space in the window where you would like to transfer the files, and select "Paste."
Your files have now been deleted from their original location and transferred to your external hard drive in the folder you selected
hope this helps
Sep 27, 2012 | SimpleTech Signature Mini 160GB External...
I dropped and dragged some sizable folders from a desktop onto the Maxtor external drive. When I plug the drive into a different computer, I only see the files that I put on the drive a year ago on the...
Several things could be happening.
1. the hard drive direct drive motor is giving out.
2. the hard drive is full.
3. the hard drive needs to be optimized ( that is defragmented) using the Windows defragment utility. If the drive is large it will take some time to complete.
Jul 22, 2011 | Maxtor Hard Drive
We have some videos we want to transfer to the computer. We are running Mac OSX with the Leopard software. When I attach the camera, I see the point and shoot icon for a short time and then I hear a beep...
Put the batteries in the camera, then connect via the USB flip connection. The camera will show up on the desktop like a flash drive does. Open it when it shows up. Drill until you find the avi movies and drag them to your desktop. You may have to convert them to quicktime files. If you cannot use the software that came with the camera (it does work), you can import the sections into iMovie.
Jul 14, 2009 | Pure Digital Flip Video Ultra Camcorder
Lost files
Have you tried to SEARCH for any file names that you put into that folder? If the search finds a file name that you placed into the folder, make a note of the location of that file, this should help you to locate the missing folder .... it's generally not a good idea to place large files or folders in the desktop, depending on the Windows version you are running. But try the SEARCH for individual file names that you remember putting into the new storage file. Let us know what happens?
Apr 10, 2009 | Sony Computers & Internet
Hi, I lost user manual, need to restore files back to computer.
Provided that you can find your external drive using My Computer feature, double click on that drive icon and search the drive for the files you wish to put on the computer drive (C drive). If you right click the file or folder on the Maxtor external drive and then choose copy, you can go to the folder on the C drive that you want to paste them into, select it and then right click the folder icon and choose paste to put them into the folder. To make the process quicker, you might choose to paste all files and/or files from the Maxtor drive onto the computer desktop and then move them around later.
Dec 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
69 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
