Torpedo heater ignites and then goes out reignites, goes out, etc.
My 100,000 btu heater (Remmington) seems not to stay ignited. It does heat but doesn't stay burning.
  • 2 more comments
  • wbaldwin Oct 16, 2008
    its kerosene! Checked the fuel filter today - not it!
  • wbaldwin Oct 18, 2008
    no smoke runs good doesn't shut down did the same last year
  • bgrifn Jan 09, 2009
    master 70 multifuel. burns awhile, flames out, burns awhile, flames out. what to do, its only a year old!
  • larrysloma1 Jan 28, 2009
    It starts and runs for 20 minutes and then stops. I shut the switch off and wait a minute then turn the switch on and it runs for 15 minutes and shuts off. I restart it and it starts and stops. I start it and it stops. Etc and etc. No smoke when starting. It is a Remington multi-fuel and ran great last winter and the winter before. Ran diesel and kerosene back and forth and was great. Waht's up?
  • 232 Answers
We need to know more. Is this a kerosene or a propane fired heater?
Posted on Oct 16, 2008
  • Jerry Magee
    Jerry Magee Oct 16, 2008
    OK, it's a kero fired heater. In order to help I need to know answers to the following questions.
    1. When it ignites, does the heater put out good clean heat or is it smokey or stinky?
    2. Put a watch to it. How long does it run before it shuts down? (#minutes, #seconds, etc)
    3. Did the heater run good last year when put away?
    Answer the questions completely and don't guess.
  • Jerry Magee
    Jerry Magee Oct 19, 2008
    Sorry, I'm lost. Your first post states "doesn't stay burning".
    Your third post states "doesn't shut down".
    Your posts seem to contradict each other unless you are saying " the flame goes out, but the motor continues to run". Is this the case? If so, :
    1. Exactly what is the model number of your 100,000 btu Remington heater?
    2. Exactly how long does the heater run until flameout?
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
Runs but wont ignite
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 13, 2011 | Reddy Heater-30-55,000 BTU Variable
Fan starts no ignition then cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jun 08, 2010 | Reddy Heater-75-125,000 BTU Variable
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
Heating & Cooling Logo
558 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
