Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Motorola SBG900 wireless router
I've recently moved and I now rent a Motorola SBG900 wireless router from my cable/internet provider. Since I've got here I'm unable to play poker online with PokerStars on my laptop and I'm unable to log on to the PlayStation Network with my PS3 although I can get them both online and use the internet brower.
The PS3 will find the IP address and connect to the internet, but it fails to log me into the PlayStation Network. I'm thinking this is similar to my PokerStars problem which the router isn't letting this through.
When I went back to the hometown this last weekend I brought my laptop and to my surprise, without changing any setting on my laptop I used my friend's wireless internet and my computer worked fine, PokerStars and all. That's why I've narrowed it down to this router.
PokerStars software uses two port numbers by default: 26002 and 443. If possible could I get someone to e-mail me a step by step process or possibly send me a website link on how to open these ports on my router. Also, if you know how to get my Playstation Network to go online I would appreciate that also.
Thank you for reading this problem and I look forward to hearing back from you.
Jeremy Cumber
  • 341 Answers
Go to portforward.com, find your router in the product list and follow the instructions. Works for me everytime.
Posted on Nov 28, 2008
Searching for password on bottom of motorola surfboard SBG900
try this link
https://www.cleancss.com/router-default/MOTOROLA/SBG900
Jan 15, 2018 | Arris Surfboard SBG900 Modem Cable Modem...
Ok.....my internet is up and running......and im useing the SB5101 Model...but when i switch it back to my SBG900....it gets stuck on the roadrunner (internet provider) web page.....it works fine with the...
Turn the cable-modem off.
Unplug the AC poewr to the cable-modem.
Turn the router off.
Unplug the AC power.
Reconnect the AC power to both the cable-modem and the router.
Turn the router on -- this off/on sequence should "reset" the cable-modem and the router.
If the router still does not work, replace it.
If the cable-modem does not work, get RoadRunner to replace it, if they want to keep you as a paying customer.
Jun 26, 2011 | Arris SURFboard SBG900 Wireless Router...
I cannot find the security key on the bottom of my motorola surfboard modem
Contact your local Internet Service Provider for assistance with your cable-modem.
Or, if you have connected a wireless-router to the cable-modem, and now you are trying to connect a wireless-device to the wireless-router, that's where a "security-key" is needed.
Dec 20, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
Sep 16, 2017 | Arris SURFboard SBG900 Wireless Router...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
SBG900 Wireless not detected
See the other post. Change the "channel" on the online settings and that should work.
Jan 12, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
322 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
