Maytag front loader MAH4000AWW: Will not drain water or lock door
My Maytag front loader washes clothes well but will not spin all of the water out. The clothes come out dripping wet. I had a repairman look at it and I honestly think he couldn't figure out what was wrong with it because he called another service guy in to help him and after awhile, they said that they wanted to take it in to their shop to repair it. I told them no. I turned it on today and now the lock door light does not come on and I can open the door while the load it washing. It still washes the clothes, but the light will not come on and the door will not lock. So, now I have two problems. HELP!
  • Anonymous Dec 21, 2008
    washes clothes fine/door does not lock/ no lock light/will not spin all the water out/clothes are dripping wet
    Novelist:
    Champion:
  • 261 Answers
There is possibly three issues here. A door lock, pump or drain and a timer can cause you problem. I would first pull the front back off and make sure all the wires are plugged in. The door shroud is the easiest to remove and put back as it locks in, be sure not to pull off the inner section of the shroud as a really nice spring is there to challenge your sanity. I will include some pics so you can see where all the screws go because explaining this is confusing, you just have to go section by section to access the door latch.
Now you need to check that the wires going to this assembly are correct, secured tightly and working. If all of this is correct go below and to the right to check the pump. I use a garbage bag to catch the water so I can inspect the pump and hoses for blockage.
Maytag front loader MAH4000AWW: Will not drain wat - 51273.png
Posted on Oct 16, 2008
Neptune front loader. doorlock light quit working. wont spin.
You will need to change the machine control board and door lock wax motor.
MAH3000AWW PART # 'S 22002988 AND 12002535
MAH4000AWW PART# 'S 22002989 AND 12002535
If yo look at your control board in the control panel you will find R11 burned.
Jun 10, 2011 | Maytag Washing Machines
I have a Maytag MAH4000AWW. Machine does not drain all of the water out after spin cycles - so clothes come out soaking wet and a little water is left in bottom of drum. Also the Door Lock light does not...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
Maytag Neptune MAH4000AWW
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
270 people viewed this question
Top Washing Machines Experts
