Question about HP Compaq T1500 XR (204203003) UPS System
Can i reset the ups alarm without turning the unit fully off and resetting ?
I have a HP T1500 XR UPS and every time that it has an alarm trigered i have to turn the unit fully off and turn back on again is their a feature that you can do this without powering down.??
  • 1894 Answers
SOURCE: Cannot get past opening screen or turn off unit. Unit seems frozen
try to restore the factory settings.. this may help
Posted on Jan 12, 2008
  • 406 Answers
SOURCE: hp printer needs help
Remove the cartridges . and reinsert cartridges .
Ithink it will solve reset problem.
rafique
Posted on Feb 15, 2008
SOURCE: HP dv6000 boot problem
I had a similar problem. You may want to attempt a hard reset on the unit first. This is simply remove power from the laptop. Remove the Battery. With all removed from the laptop...hold the power button down for one minute. Then release the power button. Plug in the battery first...then the power cord. Try powering the unit up again. This reset will not do anything but do a Hard reset on the machine. Sometimes static charge can build up on the motherboard...the PC will go into a sleep protection mode. This essentially wakes it up.
Posted on Dec 24, 2008
efs_perpends
  • 1996 Answers
SOURCE: HP C6180 won't turn on
To begin with, try resetting it by following these instructions. If you are using a usb cable, unplug it as well and wait at least a few minutes before reconnecting.
See also here and here. (different) It's possible you have too many devices plugged in and the printer is starved for power, or it's somehow grounding out.
If that doesn't solve the problem, you may find alternative solutions here. or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
rcxrbt
  • 84 Answers
SOURCE: Need program for my UPS hp t2200 xr on debian
You can find here a very good software for UPS under Linux OS:
http://www.networkupstools.org/compat/stable.html
Check if your UPS is compatible...
Posted on Oct 19, 2009
Testimonial: "thanks allot, i managed to get it working.;) "
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
HP3000 XR UPS units utility light is green and not flashing The Battery light and the General Alarm light are flashing red
If you have had the UPS for more than 5 years you will need to change the battery ... you can source replacement batteries and not have to replace the whole UPS.
Birket
Jul 14, 2011 | HP 3000 XR (j4367a) UPS System
On our 20kVa unit we got a 'battery must be checked" alarm. We replaced the battery but alarm still on unit. How can we get rid of this? We already did the normal reset but alarm still there. Thank...
The internal automatic battery test is picking up some differences between the actual value of the battery to the mathematical calculation used in the software. Normally if you do a battery impedance test you would find that the batteries would be consistent and therefore replacing the batteries may not be the solution. Once you transfer the UPS on BYPASS and then recycle the power you would clear the alarm. However on the next internal automatic battery you would be getting the same alarm again.
At times this may be a software issue or an SNMP problem. Normally to refresh the battery data for the UPS monitoring software we carry out a battery discharge test. Please consult with the supplier if an annually battery discharge test is mandatory for the battery monitoring circuit to work well. Please let me know of the outcome
Feb 04, 2011 | MGE UPS Galaxy 3000 UPS System
Have a UPS R12000 XR system, It show 1 alarm on the MM which indicates (emergency power is off). Does this require replacing the Main Module.
maybe yes, maybe not, have it check by an electronic repair center, there are no user serviceable parts inside, or you might end up messing the whole unit instead of the real damaged part,
Jun 02, 2010 | Compaq UPS R12000 XR (207552-B22) UPS...
My t1500 XR keeps clicking on and off when i connect it to the power suply. why is that and how do i solve it?
that is because the power outlet it is plugged into probably doesn't have a steady voltage. which means that if more things are plugged into the outlet then the power could be going from 120 volts to 99 volts to 130 volts and it could be going up and down like that. your ups thinks that when the power goes really low or really high their is a power outage or surge. so it clicks to battery. then when the voltage steadies out it clicks to house current. you will need to configure the ups to have to tolerate that kind of voltage. by plugging the data cord in to your computer it is either a Ethernet to usb or usb to usb, you know a cord that plugs into the ups to the computer to let you configure it.
Oct 23, 2009 | HP Compaq T1500 XR (204203003) UPS System
I lost my i-mate jam driver CD and i can't find some free download anywhere what can i do? I need it for my laptop somebody help me???
hi..did you try looking at www.download.com.. maybe you can find it there... just search the product name and it's version for you to find the Driver... thank you..
Jul 06, 2009 | Compaq UPS T1500 XR (204155-B32) UPS...
Unit is not powering up
It seems your UPS DC fuse is blown Replace it and see....sodeep
Mar 21, 2009 | Compaq UPS T1500 XR (204155-B32) UPS...
Imate driver download
either go to UPS web site and list your product and it should have drivers or updates for your product. Also you can go to Drivers.com and join (for free), list the driver you need and download it.
Dec 25, 2007 | Compaq UPS T1500 XR (204155-B32) UPS...
Utility LED flashing green/red
Seems like your Battery is very low. Try charging the battery for a few hours. If the problem persists, it maybe the time to get a new battery.
Like all batteries, UPS Batteries (that store electricity and let s you use it in case of a power failure) have a limited life. This life is averaged to be around 2 years. So in case your UPS has been in use for approximately that much amount of time, the battery is in a near death situation.
For instructions regarding replacing the battery, please refer to your UPS Manual.
PS: Also, I have noticed this kind of behavior when the UPS is connected to a socket powered by an Inverter. This kind of behavior is observed when the Inverter battery is running low.
Oct 12, 2007 | Compaq UPS T1500 XR (204155-B32) UPS...
HP Compaq T1500 XR (204203003) UPS System Logo
559 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
