Question about Refrigerators
Noisy Fridge! Help please. My refrigerator makes a terrible banging noise whenever the compressor shuts off. It wakes me up. It sounds like the expansion tank is rattling around? My landlord says it can't be fixed. Any better opinions? Thanks! GE Fridge about 11 years old. Load banging noise upon shut down. Cleaned the coils and all with compressed air. Could it be worn grommets on the compressor?
  • 120 Answers
You need a new compresor that type of work will run you like 4 to 5 G'S you are better off buying a new one. i repl compressors everyday i work for one of the major companys that go to your home to repair refrigerators
Posted on Oct 15, 2008
Mini fridge compressor makes noise when shutting off
Hello, This is normal. The compressor inside the shell is mounted on spring standoffs. It will move around when shutting off and can hit the inside of the compressor shell or will do the same if the unit is moved around. Nothing to worry about.
Apr 09, 2014 | Refrigerators
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Refrigerator runs fine and when it shuts off makes a banging sound
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 08, 2009 | Whirlpool Refrigerators
Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Sep 07, 2009 | Refrigerators
Noisy Kenmore Fridge
remove rear panel. make sure compressor is not loose. is noise inside refrigerator or outside at bottom rear?
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator condenser banging
yeah, you must have knocked the compressor when cleaning, sounds like one of internal spring/mounts in the comp' has dislodged.
replace the compressor is the only fix, unless you can somehow get to the lose spring.
Apr 25, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Noisy Fridge!
Have you ever cleaned the coil under the refrigerator? If the coil is very dirty the compressor will run very hot and when it finaly shuts off its banging is a sigh of relief. Pull the bottom panel off and vacuum inside as far as u can reach. They also sell brushes for cleaning them.
Apr 08, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerators Logo
414 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
